vent window question
Old May 25, 2014 | 12:00 AM
Lloyd399's Avatar
Lloyd399
I have noticed that my drivers side vent window tries to back out of the frame. Is there some type of moulding or adhesive that holds it in the frame?
Old May 25, 2014 | 12:12 AM
crazed87bronco's Avatar
crazed87bronco
There's a seal in the frame to hold it in place yours may be dry rotted and not look like a seal anymore or totally disintegrated. There's a thread here on the replacement of the seal from what others say they are a pain. Here's a link to a new seal.
Vent Window Seal | Dennis Carpenter Ford Restoration Parts
Old May 25, 2014 | 11:47 AM
Lloyd399's Avatar
Lloyd399
[quote=crazed87bronco;14376513]There's a seal in the frame to hold it in place yours may be dry rotted and not look like a seal anymore or totally disintegrated. "<br />
<br />
Guess I might not have explained myself well enough. The vent window glass is actually backing out of its frame. Not the frame that holds the assembly in the Door, but the frame the glass fits into. The bumps locking lever doesn't go through the glass to hold it in place. I've looked through my shop manual but have not seen a reference to what actually hold the glass in place. There has to be something that was used, whether its some type of caulking, tape or whatever. <br />
Anyone know what was used originally to do this?
Old May 25, 2014 | 12:50 PM
crazed87bronco
The glass is held in there with glass tape. You can pick it up at most any auto glass shops around your area. I don't think I've seen any good pics of anyone replacing the tape or frames. If you can post some up as a how to for others.
Old May 25, 2014 | 01:55 PM
Lloyd399's Avatar
Lloyd399
I am thinking about trying a wire wheel on a dremel to remove what remains in the glass frame. If that doesn't work, will try manual method with a small flat blade screw driver.
Old May 25, 2014 | 06:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The vent glass is retained to the frame with glass tape .. available from any auto glass shop. Glass tape is also used to bond the door glass (21410) to the window channel (21458).
Old May 25, 2014 | 07:21 PM
Lloyd399's Avatar
Lloyd399
Number dummy, I really do appreciate the exploded view you've provided.
When looking for the window tape I came across this link. While it doesn't show how to remove the old stuff, it does give some interesting tips on the install.
http://www.hotrodhotline.com/content/glass-installation-final-steps#.U4KH3dFOk0M
Old May 25, 2014 | 07:52 PM
NumberDummy
Remove the old glass tape from the frame w/a blade screwdriver. Place the glass tape on the glass, then shove it into the frame.
Once it's set up, remove the excess glass tape with a razor blade, xacto knife or any 'ol knife you happen to have layin' around including an Arkansas Tooth Pick (aka Bowie Knife).
Old May 25, 2014 | 11:03 PM
Lloyd399's Avatar
Lloyd399
I have more than a couple of Bowie's laying around. That might make for an interesting video...
Old May 26, 2014 | 02:28 AM
NumberDummy
Texican's would not only know what happened to Jim Bowie, but what occurred across the street at the Menger Hotel bar in 1898. TR met with the Rough Riders candidates.
Old May 26, 2014 | 06:44 PM
Lloyd399's Avatar
Lloyd399
To be honest, I did not know about the Menger Hotel. Always nice to learn addtional pieces of Texas history. That wasn't something that was taught in the 3 yrs of Texas history we had when I was in school. Thanks for the additional lesson!
Old Jul 1, 2017 | 11:17 AM
grantorinosport's Avatar
grantorinosport
Is there a size difference (thickness difference) between the glass tape used for the main door window and the vent window? I have no problem trimming the obviously too wide tape when used in the vent window with a knife, but I want to make sure I am using the correct thickness before I overstuff it all together.
The glass tape I have is what came from LMC. Worked great for the door window, but it "feels" like it might be too thick for the vent window. I've been too afraid to just start stuffing it in there to see just how the fit is - hence why I wanted to ask first.
Old Jul 1, 2017 | 08:50 PM
mrpotatohead's Avatar
mrpotatohead
Yeah, I would imagine the vent window uses thinner tape than the door glass.
Old Jul 1, 2017 | 10:10 PM
grantorinosport
It would seem so. Today I was able to try and install the vent window glass into the frame and was unable to with the door glass tape for the main door window.
The tape measured at about .056 to .062 (about 1/16 of an inch) and I was able to get it part way, however I could not get it all the way without really forcing it to the point of breaking the glass.
I'm thinking that perhaps 3/64 might be a better fit or perhaps 1/32. I'll have to find a place to get the tape.
Old Jul 2, 2017 | 06:05 AM
KOT390's Avatar
KOT390
Thanks everyone for posting info in this thread. I have the same problem as the OP and while I have the doors apart during paint and new seals all around, I can address this issue as well.
KOT390
