Sponsored by: Real Truck
Nitrogen in tires ??
Old Mar 1, 2008 | 12:43 PM
KingRanch250's Avatar
KingRanch250
I am picking up my new 08 6.4 Lariat on Monday. My dealer was willing to swap out my factory 20" goodyear tires for BFG K/O All terrains. He asked me if I wanted him to use "air" or nitrogen in the tires. I have never heard of this. He said that it makes the tires rum cooler and ride much better. Has anyone ever done this ?? Thanks in advance !!
Old Mar 1, 2008 | 01:08 PM
Jay2008's Avatar
Jay2008
If the dealership will do the Nitrogen for you, let them. Nitrogen doesn't disappear like air with the temperature changes. As for the ride, I wouldn't bet on any noticeable difference. On airplanes, nitrogen is all we can use otherwise the tires would be flat when we descended back down from the extreme cold at altitude. When they do that for you you'll notice you don't have to add air nearly as often as with air. Also, it's not flammable either and you can add normal air with it if you can't get to a shop that has nitro.
Old Mar 1, 2008 | 03:42 PM
KingRanch250
Thanks for the info. I will try it out
Old Mar 1, 2008 | 04:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
He's either lying or stupid, I can't tell which. Nitrogen in the tires makes ZERO difference to ride or tire temperature.
I fill my tires with a mixture that includes 78% nitrogen.
Old Mar 1, 2008 | 05:25 PM
KingRanch250
If it makes no difference in ride or tire temp, why are you running a "78 percent mixture" ???
Old Mar 1, 2008 | 06:06 PM
elee3's Avatar
elee3
He's talking about air.
Old Mar 1, 2008 | 06:09 PM
TNT in Round Rock's Avatar
TNT in Round Rock
Old Mar 1, 2008 | 06:59 PM
slowmans's Avatar
slowmans
woooohooooo im running 81%
Old Mar 1, 2008 | 07:13 PM
LaxPlaya21's Avatar
LaxPlaya21
I am not sayin who is right or wrong, but all the reading I have done about nitrogen suggests that the tires will run cooler. I have no idea why, but I have come across this often. The main reason to run nitrogen is that is leaks out of the tires at 1/3 the rate of air. And since most people rarely check air pressure of their tires regularly this means an increase in MPG. Seems like a waste to me.
Old Mar 1, 2008 | 07:24 PM
Frankenbiker's Avatar
Frankenbiker
Nitrogen in passenger vehicle tires is a waste.
The reason why aircraft use it in tires is to reduce the fire danger. A tire filled with nitrogen won't burn as easily as a tire filled with "air" (which contains oxygen).
Yet another attempt to bilk unsuspecting (i.e. stupid) consumers out of their cash.
-blaine
Old Mar 1, 2008 | 11:05 PM
Jay2008's Avatar
Jay2008
I've never had a auto/tire shop charge me for it although, I usually do it myself at the airport.
As I stated before, Nitrogen isn't flammable and isn't susceptible to temperature changes. With nitro you can check the pressure at 0 or 100 degress and it reads the same. Every aircraft I own and/or operate has it in it and it works.
Old Mar 1, 2008 | 11:57 PM
fivonut's Avatar
fivonut
If you can get it free then do it. If nothing else you won't have to worry about topping off your tire pressure.
Old Mar 2, 2008 | 01:23 AM
cartmanea's Avatar
cartmanea
All Nitrogen does is make it so your tire pressure doesn't change with temperature as much.
Old Mar 2, 2008 | 07:13 AM
Mark Kovalsky
That's not true. All gasses expand when hot and contract when cold, even nitrogen.
I work on a race team. We fill the race tires with pure nitrogen. There is less variation in pressure with temperature, but not zero variation. That's simply not possible.
The reason there is less variation is that bottled nitrogen is dry. There is almost no water vapor. If you use compressed air there is water vapor, and water vapor expands with temperature more than dry nitrogen. If your tires normally run over about 180F you will have less variation in pressure with nitrogen. You'll have many other problems because street tires are not designed to run that hot. Race tires are.
Old Mar 2, 2008 | 07:15 AM
1buzzbait's Avatar
1buzzbait
---yeah exactly what he said, and it is true--i got it in my both my trucks
