Sponsored by: Real Truck
Nitrogen in tires ??
Old Mar 3, 2008 | 01:03 AM
belandd's Avatar
belandd
Nitrogen
Nitrogen is used in acft tires because it doesn't have oxygen in it. The oxygen combines with the rubber in the tires and causes them to break down. It can create a flamable mixture.
Nitrogen probably won't make any difference in your truck tires but in the long run it is better for them.
Note the cracking in the sidewalls caused by oxygen in the atmosphere.
Old Mar 3, 2008 | 01:05 AM
cartmanea's Avatar
cartmanea
Sidewall cracking is more due to UV damage than anything. Look at tires laying outside compared to those stored inside, they both get the same amount of oxygen on them
Old Mar 3, 2008 | 05:01 AM
mitchntx's Avatar
mitchntx
Compressed nitrogen, the way it's purchased, is bone dry ... zero water or vapor.
It's used in aircraft so that the water vapor won't freeze while at altitude. Landing with a chunk of ice inside of a tire would create an imbalance that would shake the plane to death.
It's used in car tires to reduce the amount of pressure change. As mentioned earlier, the molecules are larger and the atmosphere inside the tire is drier. So as the tire heats up, the molecules aren't as "excited" nor is the water vapor beginning to form water droplets.
Because it's drier, there is less risk of rim deterioration due to rust or corrosion. It's great for trailers and RVs, which sit for long periods of time.
Old Mar 3, 2008 | 08:32 AM
wwb's Avatar
wwb
Originally Posted by cartmanea
All Nitrogen does is make it so your tire pressure doesn't change with temperature as much.
Ummmm...... I'd suggest you look up what is called the "Ideal Gas law"... for any engineers or scientists out there, think "PV=nRT". The difference in increase/decrease in pressure with temperature between Nitrogen and Air is..... ZERO.
I'm in agreement with Mark Kovalsky.... I run 78% Nitrogen (Air). I'm not sure, but I think the Nitrogen they put in the tires comes over the internet from Nigeria.
And the water..... if you have a dryer in your compressed air system, it also becomes a non-issue. It's quite easy to get the partial pressure of the water low enough to prevent dew point down to well below zero.
Old Mar 3, 2008 | 10:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
If they are charging you for it, decline the offer. Invest in a good tire pressure gauge and check your air pressure weekly. You'll be money ahead.
Old Mar 3, 2008 | 11:15 AM
cartmanea's Avatar
cartmanea
Nobody likes a smart ***. Besides, air is not an ideal monoatomic gas, so the Ideal Gas Law doesn't really apply.
Old Mar 3, 2008 | 11:49 AM
wwb's Avatar
wwb
The difference in behavior between a monatomic gas and air is a matter of nit-picking in the laboratory. In real life, it doesn't amount to diddly-squat.
Old Mar 3, 2008 | 11:57 AM
cartmanea's Avatar
cartmanea
The water vapor in air makes a huge difference in comparison with pure Nitrogen.
Old Mar 3, 2008 | 01:31 PM
wwb's Avatar
wwb
Unless your temperature and pressure conditions are such that you will encounter a phase change, water vapor (note the word "vapor") will also behave as a gas, with properties close enough to an ideal gas that you are again picking nits.
And, over the range of temperatures and pressures that light truck tires operate, unless you filled your tires from a zero-pressure start, with undried air on a 90 degree day with 90% relative humidity, it's becomes another non-issue.
Old Mar 3, 2008 | 01:42 PM
Jay2008's Avatar
Jay2008
GOOD GOD! If you like it, FINE, if you don't, don't use it! It's all subject to opinion and everybody has one. Me, I think it's great and will continue to use it.
Old Mar 3, 2008 | 01:44 PM
pfb's Avatar
pfb
Better pressure stabilization with varying temps.
*Somewhat* important if you live in a climate like Colorado, where plains Summer temps will hit 100+, and Winter mountain temps might be -20, AND you rarely check your tire pressure.
Can loose over ten pounds with that type of temperature swing!
Old Mar 3, 2008 | 01:50 PM
pfb's Avatar
pfb
  #28
dkf's Avatar
dkf
I read a test in consumer reports on nitrogen in tires. They took identical tires filled them to the same pressure and let them sit for a year. After the year Nitrogen lost like 1.7psi and reg ole air lost 3psi. I usually ignore consumer reports but that was one of the few mags to read where I was.
IMO forget nitrogen its a waste of $$$. If you need to top off your tires with nitrogen they'll charge you $5 a tire at the stealership and its a PITA to run somewhere just to fill your tires.
Old Mar 3, 2008 | 01:51 PM
  #29
pfb's Avatar
pfb
Old Mar 3, 2008 | 02:42 PM
  #30
wwb's Avatar
wwb
Originally Posted by pfb
Better pressure stabilization with varying temps......
Better take a course in Physical Chemistry or thermodynamics. Is there a difference? Yes. Does it amount to diddly squat? Emphatically, NO!!!!
Tire pressures will increase or decrease with the temperature change regardless of what gas it's filled with.... but over a temperature change of 100 degrees F, the difference in pressure change between air and nitrogen will be less than 1 psi.
If you're designing a chemical plant to produce something on a commercial scale, precise control of reactions is important.... and something like the difference in gas behavior between air and N2 may be significant. But, fellas, when you're talkin' about inflating your tires, it's a bad joke..... and a moneymaker for the guy selling it to you.
