O/D light flashing
Old Mar 18, 2008 | 02:56 PM
  #46
aklim's Avatar
aklim
Originally Posted by Markadeck
Of course what I was referring to, was physically inspecting it. Any other way of covering your tracks I'm unaware of.
They can interrogate the PCM to see if it has been reflashed or they can take the cover out and see if the goo has been scraped off the terminals which would indicate a chip. That is why I recommend that people with warranty concerns get another PCM that is chipped or chip another PCM. Problem? Take the hot one out and stuff the old one back.
Old Mar 18, 2008 | 03:05 PM
  #47
Izzy351's Avatar
Izzy351
That's why you reset it and run it for a while, aklim. Nothing incriminating there after it's been reset. After that, there's no way (other than the silicone being scrapped off) that they could see. I guess you could get really creative and get some clear silicone to put on there to really cover your tracks, but it would have to be a REALLY good application if they actually took it out to physically inspect it. The only other thing I know of is on the 6.0s -- if they pull the heads and see a big star-shaped burn pattern on the piston, it's been chipped. Stock ones have a small circular pattern. Not sure if our trucks do that or not.
But jeez, we're in '08 now. The very last of the 7.3s should be out of warranty by time if not miles anyway (unless you bought an extended warranty, I suppose).
Old Mar 18, 2008 | 03:19 PM
  #48
aklim's Avatar
aklim
I don't think so. IIRC, I saw my mechanic friend scan my PCM and he could tell me how many times it has been reprogrammed by a Superchips programmer someone tried on my vehicle.
Old Mar 18, 2008 | 03:51 PM
  #49
Izzy351's Avatar
Izzy351
Did you reset it before he saw it?
Old Mar 18, 2008 | 03:53 PM
  #50
aklim's Avatar
aklim
We did and I asked him if he could scan it and tell me if this PCM had been flashed. He can't say what has been there but he knows it was flashed 4 times.
Old Mar 18, 2008 | 04:12 PM
  #51
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by MTDewX
Mark K
yeah that might as well be, but I thought running at 35 would be taking it easy and plus the honda CRX is not a heavy load.
oh well though its running ok now. being so far away from BTS or Woods, it is possible to get parts to rebuild my tranny to make it like theres? or is better to just buy theres? this is of course the 4 year plan if my tranny holds up
Brian can ship you a built BTS trans. Just have someone install it for you, then send the core back in the same box.
Old Mar 19, 2008 | 02:43 PM
  #52
CGordon's Avatar
CGordon
Originally Posted by Mark Kovalsky
The trans doesn't care if it's a diesel or gas, too much heat is too much heat.
That leads me to believe that the trans was overfilled. If the fluid is too high the rotating parts of the trans will whip the fluid into a foam. All of this shearing of the fluid causes A LOT of heat, plus running at 35 MPH uphill in the snow means the torque converter is unlocked wiht a big load and causing A LOT of heat. All that means the trans will overheat and spit fluid out of the vent.
If it isn't overfilled now it probably won't overheat again.
Hey Mark! I've had the exact same thing happen to me. I had a question or two for you, and was trying to send you an IM but the system wouldn't let me. Do you know why that is? Should I just ask you here, or start another post? Just a question or two surrounding me overfilling my tranny, then noticing pink foam in my radiator coolant resivor, and the problems i've been experiencing since. Let me know the best why to contact you, if you don't mind that is.
Old Mar 19, 2008 | 02:46 PM
  #53
Izzy351's Avatar
Izzy351
Sounds to me like the tranny cooler in the radiator let loose. Need to get that fixed pretty quick...
Old Mar 19, 2008 | 03:21 PM
  #54
CGordon's Avatar
CGordon
Sounds like you're right! Or something is causing the ATF to get too hot. I was told that 96 ranger transmissions were known for over-heating, and that I should install at transmission cooler and re-route the ATF through that instead of the rad.
Basically I think I overfilled it.. drove it like that for too long, because eventually the tranny started missing gears from 1st to 2nd. I tried Lucas transmission fix fluid and fixed the fluid level and even adjusted the clutch selenoid, which helped for a bit. plus it being winter/cold out, and driving with the heat full blast has helped keep it cool down there. i wonder if the damage has already been done, because once i drive it for a while, start and stop it, get the heat up, i start missing hears again, and even hear some grinding that sounds like metal on metal crunching.
Old Mar 20, 2008 | 12:39 PM
  #55
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You should start another post.
I think you have to have a certain number of posts before you can use the PM part of FTE.
That sounds like the trans cooler in the radiator failed. It probably destroyed the trans by now, but we should discuss this in a new thread.
thomas910
1983 - 2012 Ranger & B-Series
Mar 18, 2013 09:45 PM
cwfwatkins
20
Jul 15, 2010 06:08 PM
Nichonj
Sep 9, 2009 09:03 AM
f150xlt96
Apr 5, 2003 10:30 AM
