2004 Ranger stalls while decelerating?? Code p0733
Old Mar 13, 2013 | 08:10 PM
thomas910's Avatar
thomas910
I have a 2004 Ford Ranger XLT 4.0L that is fully stock. Back in December the truck stalled while braking to a stop at a red light. No check engine light, no O/D light flashing, just died. I restarted it and it ran as if nothing happened. It ran fine for a few weeks and just when im thinking it was an isolated incident it happened again, restarted, ran fine. It seems to be shifting normally through all gears, every once in a while it feels like it might shift from 2nd to 3rd a little pre-mature but that may just be my imagination. A month ago I felt a VERY slight jerk, almost unnoticeable, while pulling into a parking spot and the O/D light started flashing. A couple days ago (which was a little over a month since it last happened) it done it at 3 consecutive red lights. Been running fine since. Had the code read and it was P0733 Gear 3 Incorrect Ratio. Any one with the same problem, or anyone know what may be wrong??? I changed trans fluid in February and fluid level is fine.
Old Mar 14, 2013 | 10:35 AM
Rockledge's Avatar
Rockledge
A lot of times the P0733 code (no 3rd gear) will pop up when there is a problem with the seperator plate/gasket. In such cases, other symptoms may also be evident.
Does your tranny have "engine braking" in first gear? See: https://www.ford-trucks.com/forums/3...irst-gear.html
Otherwise you could be looking at shift solenoid or line pressure causes.
Old Mar 18, 2013 | 08:37 PM
thomas910's Avatar
thomas910
yes it does have engine braking in 1st as well as in the other gears, thanks for the info
Old Mar 18, 2013 | 09:45 PM
JWC 3's Avatar
JWC 3
733 is incorrect 3rd gear ratio code . Filter , fluid , electric , mechanical issue . Did you use the proper fluid at filter change ?
dragunbayne
Escape & Escape Hybrid
Jan 21, 2019 11:07 AM
jameskgo
1997 - 2003 F150
Mar 27, 2015 04:41 PM
strokingbeast
Oct 6, 2010 12:03 PM
RJHoward247
Sep 20, 2006 09:19 AM
cherevo
Mar 23, 2004 03:08 PM
