Saw off Single Gibson Muffler-Insert Straight Pipe
Old 02-29-2008, 01:38 PM
SnowHiker's Avatar
SnowHiker
SnowHiker is offline
Was suggested to me here to do this. Sounds simpler enough. just saw off the existing muffler (in the middle of the truck) and replace with a straight pipe. will this be effective and proper?
Old 02-29-2008, 02:05 PM
xtrford's Avatar
xtrford
xtrford is offline
Yup....did mine that way and it sounds real good.
Old 02-29-2008, 10:25 PM
eveready77's Avatar
eveready77
eveready77 is offline
I second that. Dual cat back on my '02 5.4 sounds great. A good friend did his Bronco that way after hearing mine. The pipe pieces are available at Autozone or a local muffler shop can cut a piece for you in the desired size pretty cheap. Just cut the old muffler out and mig weld the new in, you'll love it.
Old 03-01-2008, 12:54 PM
SnowHiker's Avatar
SnowHiker
eveready, even though its just a single exhaust?
Old 03-01-2008, 02:39 PM
bigblock_drock's Avatar
bigblock_drock
bigblock_drock is offline
i want to do this on my mercury but looking at it the pipe b4 and after the muffler arnt straight across so ill have to find a bent/curved piece of pipe.. where would i find one with the right bend?
Old 03-01-2008, 07:55 PM
Dustin1690's Avatar
Dustin1690
Dustin1690 is offline
Might have to bend the pipe with a pipe bender or just buy pipes that are pre bent
Old 03-01-2008, 09:55 PM
chrono4's Avatar
chrono4
chrono4 is offline
If the rear section of pipe is soft mounted (stock), then you might be able to line them up. Aren't they only offset a few inches?
Old 03-01-2008, 11:35 PM
countryboy116's Avatar
countryboy116
countryboy116 is offline
why even run a pipe, just leave it dumped under the truck, thats how mine is just cut off right b4 the muffler and left it be, or just get a couple feet of pipe and get a 90 degree bend in it and put it infront of your passenger rear wheel, wont need very much pipe since ur exhaust is already right there basically
Old 03-02-2008, 07:12 PM
eveready77's Avatar
eveready77
Snow hiker, Most of the newer trucks you see with "dual" exhaust are not true dual. The exhaust is comeing out of one pipe and then split. You still have the same sound but it's coming out of two openings. Kinda like a stereo, same song playing, two speakers playing it. It should sound just fine.
bill11012
Modular V10 (6.8l)
29
03-09-2012 08:52 AM
jimh425
04-25-2007 09:39 PM
timberwolf-man
Exhaust Systems
12-22-2005 11:06 PM
superv10
08-22-2005 03:33 PM
Rpayne
Exhaust Systems
11-16-2003 05:19 PM
Quick Reply: Saw off Single Gibson Muffler-Insert Straight Pipe
