e4od problems!!!
Old Feb 27, 2008 | 12:54 PM
TheMech's Avatar
TheMech
e4od problems!!!
my 89 f350 460 efi e40d has got an issue, first when i press the gas pedal it accelerates just fine but when i go to press the gas down hard it seems like it doenst accelerate as fast as i did at partial throttle. and second, when it shifts into over drive and i go to speed up a bit it starts bucking until i press the gas down far enough to wear it shifts out of o/d. now i took the battery cables off to reset the computer and put them back on and drove around and it was like brand new then it came back to bucking again. could this be the computer problem or something else. thanks for all the help.
Old Feb 27, 2008 | 03:42 PM
shooter05's Avatar
shooter05
I would check the throttle position sensor. It sounds like its choking.
Old Feb 28, 2008 | 05:31 PM
TheMech's Avatar
TheMech
ok ill check that, i have no codes too. could also be the IAC too. how about the bucking problem, any advice there. thanks
Old Mar 16, 2008 | 06:03 PM
TheMech's Avatar
TheMech
thanks guys, i replaced the iac, and the sparks plugs, wires, cap and rotor and that fixed it. no bucking and no throttle issues, i dunno but thanks for the advice.
Kanglar
Feb 1, 2017 11:05 PM
Benchwarmers6
24
Apr 15, 2016 03:45 PM
mowagman
25
Apr 15, 2015 05:05 PM
DAT2109
Nov 27, 2013 01:38 PM
WhyFord
1978 - 1996 Big Bronco
Jul 17, 2012 05:44 AM
