1978 - 1996 Big Bronco
E4OD Transmission Won't Shift with Acceleration
Old Jul 10, 2012 | 05:35 PM
WhyFord's Avatar
WhyFord
I am having this weird problem with the E4OD transmission on my 94: it doesn't shift with pressing gas (accelerating); and it only shift when I release gas with speed. The symptom is more obvious when start from a full stop.
I did have it rebuilt only after about 70K miles from brand new. So I think that should have corrected all the factory original problems.
Anybody here had similar problem before or knows what went wrong again on this lousy transmission?
Thanks!
BTW, there is no transmission related codes stored when scanned.
Old Jul 10, 2012 | 06:41 PM
Encho's Avatar
Encho
The Southernmost Mod
Usually the trans. can be made to shift when you do just that, but I'm not sure what could cause the problem you're having, let me give it some thought, if I remember something I'll post again.
Old Jul 13, 2012 | 02:41 PM
Edgethis's Avatar
Edgethis
The E4OD is a very picky transmission.
Does it slam into gear at all when it finally shifts? OD light flash?
Hows the fluid level?
Old Jul 15, 2012 | 08:33 AM
WhyFord's Avatar
WhyFord
It's the worst transmission I ever had...
Since it's about time to change fluid/filter, I did it yesterday. I didn't find much debris on the magnet. So I think it's a good sign I may not have any serious problems.
After this, I think it runs normal now. From full stop, it will shift around 3000 rpm with pressing gas. Since I used Lucas Transmission Fix before this, I really don't know how much contribution Lucas did.
I think my problem is caused by either restricted flow/clogged filter, or sticky valves inside.
I used to have another problem with this transmission: I can hear/feel it shutters at around 42 mph. Now this problem is gone too.
Old Jul 15, 2012 | 03:05 PM
b4hntn's Avatar
b4hntn
I could use some clarification. It was rebuilt after 70K miles after rolling off the factory assembly line? The original owner of my '94 said at the end of the first year Ford warranty redid the transmission and rear end. Do you think yours got the upgrade?
Did you drain the torque converter also?
Dit the old gasket on top of filter neck come out
What codes are you getting in KOEO and CM?
You have replaced the VSS and MLPS?
Battery cables are good?
Checked the transmission harness for bare spots? Start at two connectors against fire wall under master cylinder. Runs down driver's frame, crosses over to MLPS then over the top to the solenoid pack connector on passenger rear of transmission under the heat shield. Not rubbing the front driveshaft? Connectors are clean?
Engine is good, no codes, vacuum leaks, recent oxygen sensor?
If you answered "yes" to above that leaves solenoid pack or PCM.
I suggest sending the original PCM to ECMTOGO.COM. My shift points were above 2,000 in recent years around town. After the PCM rebuild at 40 mph light throttle it shifts to 1,200 rpm. Runs like new at 196K.
You know how to drop the pan so you can replace the solenoid pack yourself. However, it cost about $100 more than the PCM even if you reuse the same fluid. With no debris in the pan and the way it is acting I am guessing the problem is electrical. On mine I replaced the solenoid pack twice then solved it with PCM rebuild.
Old Jul 15, 2012 | 07:15 PM
Encho's Avatar
Encho
From what you describe, it sounds like either the Solenoid pack or the ECM, as b4hntn stated, I would follow his advice on this one.
Old Jul 16, 2012 | 03:59 PM
WhyFord's Avatar
WhyFord
Yes. But Ford didn't do it as they should. I know some dealers may have done it out of good conscience but it's not a recall.
So I had to pay AAMCO to do it for me. Yes, they told and showed me the aluminum parts Ford used on the main shaft of this transmission! They also told me Ford don't even sell the original parts anymore. They call their new parts "heavy duty updates".
Yes, I drained the torque converter and filled with 13 qt of fluid afterwards.
The o-ring on the old filter is a little bit loose but it still stays there. I only have one 334 code now and will fix it later.
Yes, the MLPS is new.
I think my problem is fixed for now and the problem is the filter. With an old filter restricts flow, the pump can't generate enough pressure to operate the shifting mechanism.
I have a new/refurbished PCM, I think from the same place you mentioned. When it's gone last time, the car was running crazy...
I think it shift around 2000 rpm too if I don't press gas too hard (floor it).
Since I drive a Volvo C70 most of the time now, I may just forget how a real Bronco moves... :-)
Old Jul 17, 2012 | 05:44 AM
b4hntn's Avatar
b4hntn
Sorry I did not see your magnet picture before. Mine looked about like that...maybe a little more goo around the outside.
Glad you go it going. When thinking about the goo in the filter I am a fan of dropping the pan and also draining the TC rather than flushing.
Brian Patrick
Dec 3, 2015 11:14 PM
pilotadam
Dec 3, 2012 08:07 PM
Ajc11892
Aug 10, 2010 12:28 AM
sharp94xlt
24
Oct 13, 2008 04:22 PM
winchcable
13
May 15, 2008 12:40 AM
