Sponsored by: Real Truck
Rancho or Fabtech
Old Feb 24, 2008 | 08:43 AM
geraldo14's Avatar
geraldo14
Rancho or Fabtech
Hey guys, got a question or two. I have an 02 F250 SD 4X4 Extra cab 8ft bed with the Triton V-10. I'm contemplating installing a leveling kit to bring the front end up with more fender well clearence to match the back wheel well. From reading other posts it looks like the leveling kit is pretty popular. Any opinions on either company? Rancho or Fabtech?
Thanks..
Old Feb 24, 2008 | 09:16 AM
ron01sd's Avatar
ron01sd
in my opinion there all about the same when it comes to small lifts like a level kit. it makes a big diff who you pick when you get 4" or bigger. i have had good luck and ride from Rancho lifts on past truck and liked the ride. my buddy has a Fabtech lift on his chevy pickup and i've never heard him complain about it. i'd say with a level kit chose the one that is built the best and will hold up the longest.
Old Feb 24, 2008 | 09:22 AM
DCSpecial's Avatar
DCSpecial
Between the two options I'd do the the Fabtech 3.5 with the replacement shackles.
And I would recommend an adjustable trac bar and some good shocks.
Old Feb 24, 2008 | 09:27 AM
geraldo14's Avatar
geraldo14
kit
Thanks for your opinions and suggestions. Is that a 3.5" leveling kit DCSpecial?
Old Feb 24, 2008 | 09:32 AM
DCSpecial's Avatar
DCSpecial
Yes, the Fabtech hanger and shackle kit is 3.5"
Old Feb 24, 2008 | 09:38 AM
Antelope V-10's Avatar
Antelope V-10
I have the Rancho leveling kit on my truck. I went Rancho because they make seperate gas and diesel springs. I like the ride, no complaints.
Old Feb 24, 2008 | 09:54 AM
geraldo14's Avatar
geraldo14
Thanks Antelope, did you install a 2.5" kit or 3.5?
Old Feb 24, 2008 | 11:05 AM
Antelope V-10
2.5". I also put the bigger F350 blocks in the back.
Old Feb 24, 2008 | 12:15 PM
skoveng's Avatar
skoveng
I installed 4" rancho springs on my '03 F250/6.0/CC/SRW/LB just because they are the only people I know of who make different springs for gas and diesel.
I originally was going to go with a fab tech 3.5 level but the people at the 4x4 shop where I bought the lift parts told me you need to change the front bolt-on cross member and that insurance companies or ford was not covering accident damage as this was altered. Maybe just BS? I don't regret the rancho spring move. I used BDS track arm drop bracket and pitman arm along with their standard shock set-up. They said I didn't need to do anything with the stabilizer bar links but I replaced them anyway with 3" longer skyjacker links that came with poly bushings.
Happy with the set-up.
Old Feb 24, 2008 | 12:45 PM
geraldo14's Avatar
geraldo14
company
Have you heard of 'Tuff Country'? they have a 2.5" leving lift kit with added leaf spring packs 4 U bolts a front track bar. for only 300 bucks including shipping.
Old Feb 24, 2008 | 12:58 PM
cartmanea's Avatar
cartmanea
Of the two I would go Fabtech, but also take a look at Icon Vehicle Dynamics, formerly Donahoe Racing.
Old Feb 26, 2008 | 05:30 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
i'd recommend reading through the reviews here before deciding:
http://motorhaven.autoanything.com/suspension-systems/61A2616A0A0.aspx
http://motorhaven.autoanything.com/suspension-systems/61A2805A0A0.aspx
Kert0307
May 21, 2012 08:36 PM
98greensi
2004 - 2008 F150
18
Jun 3, 2008 07:55 PM
RedDragon777
1997 - 2003 F150
13
Nov 11, 2007 10:15 AM
quietman
Mar 31, 2006 08:39 PM
Rockinfigz
Jul 8, 2002 07:46 PM
