The Cure
Old Feb 22, 2008 | 08:16 PM
MADVAN's Avatar
MADVAN
Originally Posted by tjbeggs
Correct. you can get all those and not have any conflicts between them. Also here is something you might want to consider as well. I don't understand it full but I think I am gonna give it a try. It takes the place of a shift kit or valve body from what I understand so far.
http://www.eseliminator.com/index.html
Tj is correct.
This is another route to take when building your VB.
It will eliminate any/all EPC issues.
Bill
Old Feb 22, 2008 | 08:17 PM
2 stroke man's Avatar
2 stroke man
honest my tc is good. i'll video it if youll tell me what to do
Action4478's Avatar
Action4478
thats a shift point issue, a chip can address that (I think). I use my right foot to decide what gear to put it in. But that kickdown shift is sweet with The Cure I can tell you that! If I want to blow smoke I roll into it. If I want to kick it down and blow their doors off I mat it!
Who's Matt ?....
Old Feb 22, 2008 | 08:19 PM
tjbeggs's Avatar
tjbeggs
He's is this little guy that lives under my floor mat near my throttle pedal!! He replaces the factory mice on the excercise wheel!!
Old Feb 22, 2008 | 08:21 PM
MADVAN's Avatar
MADVAN
Originally Posted by Action4478
Who's Matt ?....
The guy at the station that fills the tank.
Bill
Old Feb 22, 2008 | 08:23 PM
Action4478's Avatar
Action4478
Bill
Thats Rick...I know him.....
MADVAN's Avatar
MADVAN
2stroke
All you need to do is run a test with your manual TC lock switch.
Also the cure site has a test you can run to see the differance in the shiftpoint. Try the test also.
Bill
Old Feb 22, 2008 | 08:28 PM
Action4478's Avatar
Action4478
2stroke
Bill
A little help here ..this ,is the test :
  • Get on the Interstate and accelerate, notice and feel your overdrive shift point.
  • Then manually over-ride/cancel the over-drive; repeat the process of acceleration then once over 50 MPH engage the overdrive, notice and feel the shift point again, you will see that it will not have the "Shift Flair" problem.
Old Feb 22, 2008 | 10:42 PM
2 stroke man
ya, i know about that. but my tc is good. my trans is good. it pulls like no tomarr. well, actually tomarrow its gonna have a load. like 20k ish. shifts are good even then. as in good i mean no slippage in the clutches, and no tc shutter.
Old Feb 23, 2008 | 07:18 AM
c00nhunterjoe's Avatar
c00nhunterjoe
my truck shifts the same either way.
Old Feb 23, 2008 | 07:23 AM
c00nhunterjoe
[QUOTE=tjbeggs]Correct. you can get all those and not have any conflicts between them. Also here is something you might want to consider as well. I don't understand it full but I think I am gonna give it a try. It takes the place of a shift kit or valve body from what I understand so far.
http://www.eseliminator.com/index.html[/QUOTE]
tj, that is a bundle of different shift improvers all in one price.
the 3 springs side by side replace the ones in the accumulaotr body. those 3 are going to be stiffer than the stock ones making line pressure build before it opens and shifts to make it firmer.
the 3 different colored ***** are to replace the check valve for the epc, they have 3 different sized holes do allow different levels of fluid to bypass the valve and aid in raising pressure.
the solonoid\resistor is to take the pcm out of the epc circuit altogether and raise the pressure to a set level, no more pressure changes with throttle. it will be one set pressure.
the last piece of the puzzle is the fames pump mod, changes the pumps output pressure
Old Feb 23, 2008 | 08:06 AM
MADVAN's Avatar
MADVAN
2stroke
The control will reduce heat and slippage while at TC shiftpoints.
It put the power to the ground much faster with the reduced slippage.
You can see it in your boost gauge and seat of the pants ride. Your turbo will stay spooled.
Bill
Old Feb 23, 2008 | 08:07 AM
  #28
tjbeggs's Avatar
tjbeggs
Thanks Joe. That pretty much what I have figured out. Decided it mainly a sonnax spring kit with EPC eliminator. Price is right and sounds like a great theory! Gonna give it a go soon.
Old Feb 23, 2008 | 08:09 AM
  #29
MADVAN's Avatar
MADVAN
Then i would not install one c00n.
Your boob tubes show different.
It happens in ALL E4OD's. Some are worse than others.
On another Note.
If you donot have an issue why are we waiting for the "c00n cure comming soon?'
https://www.ford-trucks.com/forums/7...ming-soon.html
Bill
Old Feb 23, 2008 | 08:12 AM
  #30
MADVAN's Avatar
MADVAN
[QUOTE=c00nhunterjoe]
c00n
It takes the EPC out of the picture.
Ask yourself this. What is the EPC's job? and why?
The EPC is a problem when using tuners that change shiftpoints.
The pump becomes RPM related to line pressure.
Higher RPM= higher line. They rise together.
ESE works great! It actually induces leaks from the VB to lower pressure at low rpm.
Bill
