AOD Shift Problems
Old Feb 18, 2008 | 09:42 PM
clavin001's Avatar
clavin001
AOD Shift Problems
Hey, new to the site. I have a 1990 f150 4x4 with 302 and AOD tranny. Experiencing poor shifting since I got it (119000 miles when I got it, now has 140000 miles).
I tuned the truck (rotor, cap, plugs, wires). The tranny was flushed, filter changed, and an additive added. Adjusted the TV cable as per manual. Tranny seems to shift early. When cruising down the highway (65-75) will lose speed at the slightest grade. Have to keep down shifting to get back up to speed. If I'm in overdrive and manually shift down to drive, engine rpm sometimes flares. Towed a trailer with about 1000 lbs and truck was a guttless wonder. Planning on installing a shift kit, but still not sure if transmission is the problem or maybe the motor is just shot. Any ideas?
Old Feb 19, 2008 | 01:47 AM
jnewkirk77's Avatar
jnewkirk77
On my '87 4x2 with AOD, I have a sticker on the sun visor that advises towing in drive, not overdrive, and if I had to guess, it's for the reasons you mention. I've not hauled a lot of heavy loads in mine (and have yet to tow anything, because I just don't think this truck was made for that -- it's only rated 4900# GVW).
Like yours, my truck loses speed and downshifts really easily when I go to catch back up to the speed I wanted. I've gotten used to it, so it's really not a big issue. We have a good many hills around here, too, which I am sure is part of it.
Of course, I've got over 246K miles on mine ... I really shouldn't gripe. It runs, gets me from A to B and back again, which is really the point, I guess.
Old Feb 19, 2008 | 04:41 AM
clavin001's Avatar
clavin001
No, I wasn't towing in OD. Looking through the other threads on here, it seems that maybe the AOD just shifts like this.
Old Feb 19, 2008 | 06:28 AM
albung's Avatar
albung
my aod is the same way. A shift kit from transgo will make it able to hold gears longer before shifting
Old Feb 19, 2008 | 08:10 AM
Conanski's Avatar
Conanski
Welcome to the world of Ford trucks. The stock 302 in these early trucks is smothered beyond all things sensible, and to make matters worse you probably have a truck with high gearing(low numerically). A shift kit will improve the tranny behaviour, but you'll need a gear change to give the little Wheezer the mechanical advantage it needs to haul it's own *** around. Check the decal on the door pillar for the axle code. There are also lots of bolt-on goodies that will help the motor breath a little better and produce more power, and you can look at advancing the timing to give it a little more torque.
P.S. if you increase preload on the TV cable slightly from the recommended setting the shift points will be later.
Old Feb 19, 2008 | 08:43 AM
jnewkirk77's Avatar
jnewkirk77
I decided after my earlier post to dig through the large envelope of paperwork Big Red's previous owner gave me. I knew she had the tranny rebuilt, and I've mentioned before that I noticed that my transmission seemed to shift later.
Well, in all of that paperwork was the invoice for the rebuild, and it has the very Transgo shift kit albung mentioned. Guess I'm money ahead.
Old Feb 19, 2008 | 11:40 PM
clavin001's Avatar
clavin001
Yeah, I thought about a gear change too. It has 3.55 with the limited slip. When I bought it, it had 31x10.50's, so I changed it back to 235/75 R15 but didn't see much difference. I'm tired of sitting close to the ground so the hell with it, I'm putting bigger tires on. How much worse can it be??? How do I know if I have too much preload on the TV cable?
Old Feb 20, 2008 | 08:07 AM
Conanski's Avatar
Conanski
The shifts will be late and very hard, but there's no real danger of damaging the tranny from this. You can damage it from too little preload however. Carefully remove the clip on the cable adjuster and pull it out 1 notch, then take it for a drive, this should make a difference. Do this a couple times until you find the behavior you like.
3.55 gears are not the worst in the world, but as stated this motor is strangled badly. The best thing you could do is replace the whole exhaust system and upgrade the cam, but if that's more than you're prepared for consider adding 1.7 roller rockers and/or ditching the stock exhaust system.
Old Feb 20, 2008 | 06:16 PM
clavin001's Avatar
clavin001
Ok. Thanks for the info. Looks like I have a little work to do when the weather gets better
tjc295
Oct 29, 2010 04:23 PM
IHF250fireman
Feb 4, 2009 10:31 AM
Iantiler
Sep 27, 2008 10:05 PM
xltcrunch
Oct 16, 2004 01:00 PM
Rintin69
Mar 3, 2004 04:17 PM
