Problems with AOD
Old Mar 2, 2004 | 11:00 PM
Rintin69's Avatar
Rintin69
Problems with AOD
I have a 1986 Ford F150 4x4 w/302 and an AOD trans. The problem is, if you pull it down in 1st, and start to accelerate, then shift up the the next gear(D), it wont shift until I let off the gas. I stayed in the throttle once to see if it just shifted that much higher and it was almost up to 6,000 rpm's, so I backed off and it shifted right away. What would cause this problem? It is a remanufactured tranny with about 10,000 miles on it. Thanks
Old Mar 3, 2004 | 08:27 AM
fishmanndotcom's Avatar
fishmanndotcom
sounds like your torque converter is starting to go...why do you shift? (i do so i can't talk )
-jason-
Old Mar 3, 2004 | 08:33 AM
Rintin69's Avatar
Rintin69
I bought a G-Tech Pro so I was just trying it out to see what my truck had. But it did it over a year ago once when I was messing around, and I just never shifted it after that. Another weird thing is that the tranny will totally free wheel if you let off in first gear, if the shifter is down in first gear and the revs are up. When it slows to about 10 mph or so, then it will catch again and you can feel engine breaking happening.
Old Mar 3, 2004 | 04:17 PM
otto's Avatar
otto
sounds like the tv cable is not actuating the governor, or the governor is broke im guessing the former tho
minnesotafisherman
Aug 31, 2012 09:14 PM
tired51
Mar 20, 2011 10:07 PM
daboot
Nov 3, 2009 05:51 PM
Red69
Jun 15, 2009 10:34 AM
cwlightning03
1978 - 1996 Big Bronco
Feb 11, 2009 11:50 AM
