Spewing oil
Old Feb 13, 2008 | 04:22 PM
rustydailey's Avatar
rustydailey
Not to hijack, but I have the same spewing oil problem. I do know that its not from the rear of the engine. It leaks right on top of the front axle. I sat letting the engine warm up the other day and when I came back I noticed a huge puddle. But I can't find any where that the oil is coming from. I do know that it is coming from the drivers side. Other than that I know nothing else.
Old Feb 13, 2008 | 04:39 PM
pullinair's Avatar
pullinair
I have always diagnosed oil leaks on this truck by laying on top of the engine and cleaning the valley with a rag and some brake cleaner. Then I would run the truck as long as it would take to replicate the leak to see exactly where it was coming from. Then make necessary repairs after you get an idea of what needs to be fixed. Sometimes cleaning the valley can take alot of rags if you ahve a ton of oil oeddling there but you have to start somewhere.
Old Feb 18, 2008 | 09:46 AM
DieselCamper01's Avatar
DieselCamper01
Just an update to tie up this thread. Replaced the turbo pedastal and put in the EBPV
delete this weekend. All went well. No leaks. Thanks again to all who contributed. I do have a small slice in the Blue, hot side intercooler boot. What havepeople done to replace those? The dealer get $40 for a stock one
Old Feb 18, 2008 | 10:01 AM
rbaker6336's Avatar
rbaker6336
I got the boots fron Diesel Site they are a lot better
Old Feb 18, 2008 | 11:32 AM
DieselCamper01
Thanks Ray. That is also what my searching seemed to come up with also. I checked with NAPA first when I found the problem but they only sell some kind of tubing in a
3-4 foot chunk. I do not know if it would even hold up. I remember reading in the past about people using boots from a marine application but I could not locate the specifics.
Old Feb 18, 2008 | 11:51 AM
just another truck's Avatar
just another truck
ALso check "marine" type garages, you may find the boots stocked there. How was the EBPV delete?
Old Feb 18, 2008 | 12:23 PM
DieselCamper01
Taking my time and with a buddy helping it only took about 4 1/2 hours. All went
really well. No broken or stripped bolts. Always good. Boy am I sore though! I have
to give a nod to PB Blaster. Wow, that stuff is awesome!
Pat, Thank you for asking and for the input on the boots.
Old Feb 18, 2008 | 12:29 PM
pullinair's Avatar
pullinair
Glead to hear everything worked out for ya. Happy powerstroking!
97_Stroke
Feb 4, 2012 12:20 AM
Superduty krazy
21
Jul 15, 2008 06:05 AM
Marty86
15
Apr 27, 2007 03:01 PM
StillPlaysWithTrucks
1983 - 2012 Ranger & B-Series
Nov 11, 2003 02:31 PM
