HELP>>>>did up pipes and now have problem with the turbo pedistal
I did my upies last night till 2 am blah ...anyhow todAY I found a bad oil leak got home from work pulled it apart to find that the rod that comes out of the pedestal is spewing oil out can i pull that rod out and plug the hole do i need that rod if i wire the flap open...going to the pinks arm drop to race my sled tommorow morning and this is my only ride help pls
That would make sense to me. I thought the rod was common just to seep oil, not spew it out.
Still not much luck on my search, but from what I've gathered so far, you can unscrew the rod (someone suggested slipping a 3/8" pipe over it to support it, and put the rod back in. You do need to wire the butterfly valve open so it doesn't flop around.
Edit: Found what I was thinking of. It was from Heatstroked. https://www.ford-trucks.com/forums/6...-pedastal.html
If you gut the pedestal, you can tap the hole and stick a bolt in there. If you don't want to remove the pedestal to gut it, and you disconnect the actuator arm you need to slip something over the rod to support it.
Just got off the phone with him. He had already deleted the EBPV actuator and was getting ready to throw it back in. Said the actuator arm was clean from the oil blowing across it. Sent him this video to check his work.
Maintain is known on other sites for his great videos including videos of a recent rebuild.
Video of Gut and Plug - Photobucket - Video and Image Hosting
