Power steering pressure lines
Old Feb 18, 2008 | 10:17 AM
john_from_ict's Avatar
john_from_ict
Has anyone swapped their power steering pressure lines? Anything special I should know, tools, etc before I start?
Old Feb 18, 2008 | 11:32 AM
bdrummonds's Avatar
bdrummonds
I don't think you need any special tools they are pretty much plug and play.
Old Feb 18, 2008 | 12:38 PM
clintbonnie's Avatar
clintbonnie
They should be torqued to a spec.. not sure how much.. They will seem loose, but if torqued properly, they won't leak. (too much torqued is not good)... Both ends" of the high pressure "line" (not the fittings) should wiggle slightly if installed properly.. The o ring is what seals the oil..
