Steering
Old Feb 5, 2008 | 06:22 PM
F0rdF0rever's Avatar
F0rdF0rever
Steering
I need some help here. After the new springs and all new linkage up front im getting a shaky steering wheel when I hit bumps. I had it aligned today and it didnt do it before all the work. At least not as much. Is this something a steering stabilizer is used for?
Old Feb 5, 2008 | 06:29 PM
Action4478's Avatar
Action4478
...What did you do with the track bar?....
Old Feb 5, 2008 | 06:32 PM
F0rdF0rever
The track bar is dropped with the bracket supplied with the sky rsk.
Old Feb 20, 2008 | 08:17 PM
F0rdF0rever
Im still have the shaky steering wheel problem. The stabilizer didnt stop it. Something is wrong. All the tie rods, linkage, and ball joints are new. Is there a torque spec for the castle nuts on the tie rods? Also, could a bad box cause this? Its still under warranty, I might replace and see. Its odd that it didnt do this at all before I replaced all the the linkage and got it aligned.
Any ideas guys?
Steve
Old Feb 20, 2008 | 08:33 PM
tjbeggs's Avatar
tjbeggs
you need a drop pitman arm. You are feeling bumpsteer. Your track bar and drag link need to be at the same angle across the truck.
Old Feb 20, 2008 | 08:37 PM
F0rdF0rever
I have a drop pitman arm installed already. But it does feel sort of like what bump steer feels like, only more intense.
Old Feb 20, 2008 | 08:43 PM
tjbeggs's Avatar
tjbeggs
Check the angles of you track bar compared to your drag link. If they aren't nearly the same you either need to drop/raise the trackbar (may also need to build an adjustable trackbar) or you need a longer drop pitman arm.
Old Feb 20, 2008 | 08:45 PM
F0rdF0rever
Ill check it out in the morning Tim. I hope thats all it is.
Thanks!
Steve
Old Feb 21, 2008 | 02:30 PM
F0rdF0rever
I checked the angles today and they are pretty close if not exactly in line with each other. Next im guessing wheel bearings. Would that cause this?
Old Feb 21, 2008 | 05:18 PM
dauto's Avatar
dauto
Check the trac-bar bushings and recheck the bolts.
Old Feb 21, 2008 | 05:21 PM
F0rdF0rever
Track bar bushings are new. Im pretty sure the bolts are tight, but ill double check. Could a loose track bar really cause this horrible bump steer like conditions?
Old Feb 21, 2008 | 08:02 PM
F0rdF0rever
I just checked the track bar bolts, they are tight.
Old Feb 21, 2008 | 10:31 PM
okfarrier's Avatar
okfarrier
Is there ant slack in steering wheel side to side? If so try tightening the adjuster screw on steering box.
Old Feb 22, 2008 | 03:28 PM
F0rdF0rever
Well I got my problem fixed today! What a relief. Turned out to be my drivers side wheel bearings. Both the inner and outer were toast. I blame myself for this one. When I did the ball joints I over tightened the axle nuts. I just cranked them on there. Reading through my manual today I found that the first nut is only supposed to be torqued to 50lbs and then backed off 90'. I had it torqued to 150lbs! Live and learn right?
Steve
Old Feb 22, 2008 | 04:30 PM
tjbeggs's Avatar
tjbeggs
wow I guess that would do it. Surprised it causes the issue you had though. Go one to file away though!
Tparkin99
18
Feb 13, 2022 06:28 AM
ibewshooter
2015 - 2020 F150
Apr 22, 2016 07:46 AM
bigbubba87
Dec 30, 2015 10:17 AM
Jack Frost
Sep 29, 2013 07:28 PM
jcbx
28
Nov 10, 2011 07:28 PM
