Sponsored by: Real Truck
Steering Pump filter - which hose ?
Old Aug 27, 2013 | 08:01 PM
Jack Frost's Avatar
Jack Frost
I have put a new steering pump on my 2002 f250 and all new hydraulic hoses. I plan to install a steering pump filter on the system to help protect it from anything that is not steering pump fluid.
There are two intake ports to the steering pump. One is near the bottom of the pump and takes fluid from the steering pump cooler after it has left the steering gear. The other intake port is near the top of the pump and takes fluid from the booster.
My question is - which hose would be better to put a steering pump filter on? Is there anything wrong with putting a filter on both? I imagine the first intake hose is constantly circulating fluid and the other only circulates it when the steering wheel is used.
Old Aug 27, 2013 | 10:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
The return hose is low pressure so that is your best choice. I wouldn't cut either of the high pressure hoses. Many aftermarket PS pumps have an internal magnetic filter...I think the OE pumps just had a screen and it eventually gets clogged over time. Took my truck avout 300k miles before the screen clogged enough to inhibit performance.
My $0.02....
Old Aug 29, 2013 | 08:43 AM
Jack Frost's Avatar
Jack Frost
There are two return hoses to the power steering pump and I was wondering which one should be used for the filter.
Old Sep 28, 2013 | 10:41 PM
SpringerPop's Avatar
SpringerPop
Shown somewhere in this article is the one I used:
SpringerPop's Hydraulic Filter
Pop
Old Sep 29, 2013 | 07:28 PM
Jack Frost's Avatar
Jack Frost
That will be my spring project. Thanks ...
dvdgzzrll
Oct 17, 2010 06:47 PM
99F-250lova
Feb 15, 2006 11:24 AM
dnakirks
Mar 31, 2004 08:52 PM
aj5601
1978 - 1996 Big Bronco
Sep 18, 2002 12:05 PM
noey
Jul 10, 2001 05:30 PM
