Brakes grabbing
Old Feb 4, 2008 | 07:25 PM
97 RED PSD's Avatar
97 RED PSD
Brakes grabbing
My brakes seem to really be grabbing/locking up if it is wet outside or even snowing or icy. Not sure what would cause this. Also, the ABS light comes on at startup for just a few seconds. Is this normal? I can't remember if it has always done this. Any help would be greatly appreciated.
Old Feb 4, 2008 | 07:30 PM
tjbeggs's Avatar
tjbeggs
ABS light is normal. Grabbing when humid is also normal. Does it usually just go it the first stop of the day or drive cylce then seem to be fine the rest of the time? also just double check the brake fluid level and check the rear brakes for signs of leakage on the backing plates.
Old Feb 5, 2008 | 03:15 PM
2 stroke man's Avatar
2 stroke man
mine were doin this a short time back. my buddy was acting stupid and powerbraked it enough for them to spin about 3 times and nomore problem. i think they were getting corroded in the rain
Old Feb 5, 2008 | 04:50 PM
ckal704's Avatar
ckal704
It happens to me all the time. But after the initial grabby reaction, they work fine.
Old Feb 5, 2008 | 05:14 PM
c00nhunterjoe's Avatar
c00nhunterjoe
alot of time its in the quality of the shoes. cheaper shoes do it worse, typicly its only for the first few applications till the shoes get heated up, thats ok. if it does it everytime then its most likely contaminated shoes from oil. if there is no oil you can scuff the shoes and chamfer the edges to get a lot of relief. its simple to see where the shoes hit first on the drum by the wear pattern on the shoes, adjust using cookies for an angle grinder and chamfer the top and bottom edge of both shoes to relieve the issue
Old Feb 5, 2008 | 07:29 PM
97 RED PSD's Avatar
97 RED PSD
Thanks. It seems to do it just the first few times so maybe that is just normall and I will have to deal with it. I will check the shoes though and see what type of wear pattern they are showing. Thanks for the tips
Old Feb 5, 2008 | 08:26 PM
c00nhunterjoe
since they are only doing it the first few times try chamfering them and checking for high spots in the shoes
Baer
1997 - 2003 F150
May 17, 2012 09:47 PM
fordfinatic
Jan 31, 2009 06:50 PM
fordfinatic
Jan 23, 2009 06:57 PM
wmiller
May 22, 2008 06:33 AM
slangvel
Jun 10, 2006 07:32 PM
