brakes grab
Old May 21, 2008 | 11:25 AM
wmiller's Avatar
wmiller
brakes grab
when i get in the truck first thing in the morning the rear brakes lock up and squeel the first 2 or 3 times i use the brakes then they are fine. What is causing this? I replaced the drums within the last 3 months
Old May 21, 2008 | 11:37 AM
Action4478's Avatar
Action4478
I had this recently from a leaking axle seal on the R Rear ,, ....There was garbage on the shoes ...
Old May 21, 2008 | 12:05 PM
wmiller's Avatar
wmiller
that would make sense. How hard is the seal to replace?
Old May 21, 2008 | 07:24 PM
c00nhunterjoe's Avatar
c00nhunterjoe
not bad, you need a special socket to get the nut off, i have it if you need to borrow it.
Old May 21, 2008 | 07:37 PM
FARM69's Avatar
FARM69
I did mine over a year ago... axle seals were leaking pretty bad. I ended up doing a whole rear end service. How long do those seals last? I see I have a moist drum again..pry axle seal = pry why my parking brake sucks.
Old May 21, 2008 | 08:17 PM
tjbeggs's Avatar
tjbeggs
If your gonna do axle seals use the Scotseal PlusXL made by Chicago Rawhide. By far the best seal out there! Part number 34384 at Napa
Old May 22, 2008 | 06:33 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
right on tim i know for a fact i have a leaky seal on driver side -part #s make things easy
cowgirlup11
Nov 29, 2012 11:39 AM
my996duc1
6.7L Power Stroke Diesel
Jul 28, 2012 12:10 PM
ctomesh
Jan 29, 2011 06:27 PM
DCAM
Jan 26, 2008 01:13 PM
