Sponsored by: Real Truck
'99 SD Brakes
Old Jun 9, 2006 | 06:37 AM
slangvel's Avatar
slangvel
'99 SD Brakes
Have 1100 miles on new set of disk pads, now all kinds of noise and what seems like a grabbing sensation, on 1 side. Could one of those V springs that fit on the back of the pads have broken and would it cause this, or do I have something else possibly. 184K on the truck and this is the only problem I have other than a speed sensor sometime back, thanks in advance for any help or suggestions.
Old Jun 9, 2006 | 03:08 PM
biz4two's Avatar
biz4two
Arrow
When you installed the brakes, did you grease/lube the caliper slide pins? That is what it sounds like to me.
Here is an FTE link with more info:
https://www.ford-trucks.com/forums/s...d.php?t=478425
Maybe more folks will chime in...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Jun 10, 2006 | 07:32 PM
shapel's Avatar
shapel
When you put the wheel back on did you torque the lug nuts in the right pattern? If not, you might have warped the rotor. Also if you replace one rotor, you really need to replace both sides.
headleyj
Aug 1, 2014 09:50 AM
shark1979
Sep 21, 2009 10:11 PM
southbound35west
Jan 13, 2009 04:01 PM
JimAllen
Jul 29, 2007 10:50 PM
ford390gashog
Feb 20, 2005 10:32 PM
