99 f150 4x4 weird brake problem
Old 01-26-2012, 09:20 PM
Baer's Avatar
Baer
Baer is offline
On said truck, when you go to stop, the brakes grab a bit, then release , then the pedal goes to about 2 inches off the floor, then they grab and hold. Pumping does nothing. No abs light on the dash. Today we put the truck in 4high and while back up I had full brake pressure from the top. Also when you take off, either in the mornings or during the day, it has a slight vibration, kinda like a brake grabbing, then all is fine. The brake grabbing isn't there 100% of the time, I would say 95%.
Any ideas? I haven't changed the brake pads, rotors, or anything yet. Just didn't want to throw money at it and still not fix the problem.
Thanks
Old 01-26-2012, 09:32 PM
Rebuild101's Avatar
Rebuild101
Rebuild101 is offline
Well you can start by looking for leaks rust holes in the break lines
Then inspect the pads and rotors f and b make sure calapers arent sticking
That's where I would start process of alimentation
Keep us posted
How many miles on the truck?
Old 01-27-2012, 05:36 AM
Baer's Avatar
Baer
Baer is offline
truck has 171000 on it. Will check it out this weekend. Suppose to be dry, just chilly.
Old 05-17-2012, 11:56 AM
super_steve85's Avatar
super_steve85
super_steve85 is offline
I've been having this exact problem in my 2000 F-150 4x4. 180k miles on it. It only does this at very low speeds, though. If I am stopping quickly, it brakes normally. If I stop gradually the pedal will get soft and drop a couple inches, and then firm back up. There is also a bit of a groaning noise. Were you able to figure out the problem? I figured it was an ABS sensor or something.
Let me know, please. Thanks!
Old 05-17-2012, 09:47 PM
Baer's Avatar
Baer
Baer is offline
I put new brakes and drums and rotors all the way around it. Fixed the problem.
pgw85706
1983 - 2012 Ranger & B-Series
12-03-2010 10:45 AM
THEDON117
03-24-2009 12:08 AM
hood
08-07-2007 01:44 AM
RangerBiff
02-10-2005 01:05 PM
Tim13
1997 - 2003 F150
05-13-2003 07:55 PM
Quick Reply: 99 f150 4x4 weird brake problem
