RPM Sensor
Old Feb 13, 2008 | 03:25 PM
dakotajeep's Avatar
dakotajeep
I was tracing the wires from the FIPL and found a connection along the way. What is this for? Do I need this or can I run the wires straight from the FIPL to the PCM?
Old Feb 13, 2008 | 11:19 PM
ford trans tech's Avatar
ford trans tech
you can run the wires straight to the pcm , connectors are placed in the system for assembly plant purposes
Old Feb 14, 2008 | 06:01 PM
dakotajeep's Avatar
dakotajeep
sweet, I may get to this next weekend.....or nine days.....
Old Feb 16, 2008 | 04:16 PM
dakotajeep's Avatar
dakotajeep
I have been told but did not write it down....
Which pin #'s go with the FIPL wires....mine are pretty dirty and hard to ID...
Thad
Old Feb 19, 2008 | 06:42 PM
dakotajeep's Avatar
dakotajeep
Ok, I got a wild hair and gave the idle a good look. It seems to have been idling closer to 750-800rpm. I turned it down to around 650. I then reset the FIPL. The torque converter hasnt acted up since. I have driven it over 350 without a blip. The only issue now is that I still have hard shifts. The tranny also seems uncertain how to shift properly at anything above a slow acceleration (I drive slow almost everywhere). But when I do have to get on it, it shifts weird. During slow accelerations it holds onto the gears to long before shifting. But I havent had the tranny operate properly sinceI've owned it so maybe thats how they are.
The truck has 160,000 miles on it now. Does anyone think it might need to be rebuilt? I was thinking about taking it to Ford and having them do it. I will be making a long haul this fall, so I want it to be ready for the trip.....
Thad
Old Feb 19, 2008 | 06:52 PM
David85's Avatar
David85
I know its a little late to be asking this, but does your speedometer read steady?
Old Feb 19, 2008 | 09:53 PM
dakotajeep's Avatar
dakotajeep
No, I have a thread on that right now. Pete is doing some research on it for me. And I replaced the VSS and it is still doing the same thing....
Old Feb 19, 2008 | 10:01 PM
David85's Avatar
David85
So you have replaced all the sensors by now?
f100guy
62
Feb 2, 2026 04:15 PM
HeatGeek
Jan 16, 2015 02:22 PM
Macs1964F100
Jul 13, 2014 07:31 PM
b4hntn
1978 - 1996 Big Bronco
18
Feb 24, 2011 06:03 AM
budperm
Jul 29, 2007 02:12 PM
