RPM Sensor
Old Feb 2, 2008 | 05:21 PM
dakotajeep's Avatar
dakotajeep
RPM Sensor
I just tested the RPM sensor. I unhooked the connector and put my pos lead into each side with the neg at the battery. According to what I read here:
https://www.ford-trucks.com/forums/2...-the-mlps.html
I should get and increase in the voltage reading. I got nothing so.... I am assuming that my RPM sensor is bad. Would I be correct? Or is there other possibilities?
Thad
Old Feb 2, 2008 | 06:02 PM
David85's Avatar
David85
Does your tach work?
Old Feb 2, 2008 | 06:14 PM
dakotajeep's Avatar
dakotajeep
It seems to function correctly but I am curious if its sending bad signals elsewhere.
Thad
Old Feb 2, 2008 | 06:23 PM
David85's Avatar
David85
Thad
If your tach reading is accurate and steady, than its probably not the sensor. But I think you made a mistake with your test.
1.RPM sensor
Diesel only- very common Ford part # E5TZ-17B384-A. May or may not set code 14/211 (RPM sensor circuit failure). A bad RPM sensor can cause LU and/ or the shifls to go in and out (cycle back and forth).
Check RPM sensor with DVOM set to on AC voltage. RPM sensor is
located below the engine oil filler neck in the housing.
Here's how to check it
1. Remove 2-wire connector end.
2. Hook meter leads to pins on sensor. It doesn't matter which way you hook up the red or black leads.
3. Set scale to AC/ 0 to 40-volt scale..
4. Start engine in park. Raise rpm while watching DVOM.
5. Voltage must increase or RPM sensor is bad.
One lead goes to each wire, and nothing is grounded to the chassis, also make sure the meter is set to AC nor DC. Polarity does not matter since this is an AC signal.
Old Feb 2, 2008 | 11:18 PM
dakotajeep's Avatar
dakotajeep
I tried putting both leads on the connector end and got nothing trying that.....It was set to AC as described!
Thad
Old Feb 3, 2008 | 09:50 PM
ford trans tech's Avatar
ford trans tech
it also depends on the sampling rate of the tester a voltage test isnt a good test at any rate on the tach sensor , it can be faulty but still emit a/c voltage the only real test is with a hertz meter
Old Feb 4, 2008 | 09:02 AM
dakotajeep's Avatar
dakotajeep
I think that I am going to replace the VSS and the RPM sensor just to rule them out. They are not that expensive. If that doesnt work at least I have replacements.....
I am trying to figure out my torque converter locking and unlocking issue. Maybe this will help. The more I think about it, it seems that I maybe way off.
Thad
Old Feb 4, 2008 | 10:13 AM
PLC7.3's Avatar
PLC7.3
Check your brake pedal assy and switch....... the pedal assy can operate the switch if there is worn bushings etc any brake light operation unlocks the TC.
Old Feb 4, 2008 | 06:58 PM
dakotajeep's Avatar
dakotajeep
Pete
I was monitoring the tail lights as I was driving the other night and its seems to lock and unlock without the tail lights coming on.
I read on the diesel stop that you said there is a solenoid in the tranny solenoid pack that operates the TC. Is that a possibility? Just curious....
Thad
Old Feb 4, 2008 | 10:15 PM
ford trans tech
the solenoid you are speaking of is called the TCC solenoid it is part of the solenoid assembly quite costly and extremely rare to fail such as your description , my #1 guess would be the fipl sensor due to fluctuating voltage , the vss usually affects gear command and not just tcc cycling the tach sensor could be a concern if it has intermittant signal spikes
Old Feb 5, 2008 | 05:57 PM
dakotajeep's Avatar
dakotajeep
The FIPL reads correctly on the middle wire but it has bad signals on the other two (ground and reference voltage wires).
THad
Old Feb 5, 2008 | 10:11 PM
ford trans tech
have you replaced the fipl sensor
Old Feb 5, 2008 | 10:31 PM
dakotajeep's Avatar
dakotajeep
yes, twice.....
Old Feb 5, 2008 | 10:39 PM
ford trans tech
since you are having issues and have replaced it and also based on past experience , i recommend installing three new wires from the fipl to the pcm you can run them individually of the wiring loom and just cut the connections a few inches from the pcm and the fipl eliminate the original three wires with new ones if you have the tools and experience soldering the splices and using heat shrink tubing to insulate the connection is best
Old Feb 6, 2008 | 06:58 AM
dakotajeep's Avatar
dakotajeep
I may try that....it will be a few weeks until I have "extra" time.
Thanks
Thad
