Timing Problems
Old Aug 17, 2001 | 01:42 PM
79F2504x4's Avatar
79F2504x4
Timing Problems
My first question is, on a 71 block there is a Z or an N shape mark to set the timing. Where is zero in relation to this mark. And how the hell do i get the hold down bolt on the distributor off. Are there certain tools or tricks.
Please Help
Chase
1979 F-250 4x4
460 Holley650, MSD OFFROAD, Flex-a-lite fan
C6-B&M Transpack
Dana HD44Front/60Rear 3.73 Limited Slip
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Old Aug 17, 2001 | 07:49 PM
proud owner's Avatar
proud owner
Timing Problems
They make distributor wrenches that are offset to clear the distributor head and get underneath to the bolt. Go to your local parts store and ask for one for that engine.. Not expensive, and something you are bound to use again in the lifetime of the engine.
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old Aug 17, 2001 | 09:58 PM
cobrajet's Avatar
cobrajet
Timing Problems
or you might try a few ratchet extensions and a swivel or two.
Old Aug 17, 2001 | 11:26 PM
Torky's Avatar
Torky
Timing Problems
Or a Crowfoot on a 3/8" extension bar. Works for me.
Old Aug 18, 2001 | 02:43 AM
79supercab4x4's Avatar
79supercab4x4
Timing Problems
kg1784
Apr 2, 2006 03:09 PM
kg1784
Offroad & 4x4
Apr 2, 2006 12:04 PM
Highboy70
Mar 27, 2003 10:15 PM
79F2504x4
Aug 24, 2001 11:58 PM
beratte
Sep 7, 2000 10:21 PM
