My first question is, on a 71 block there is a Z or an N shape mark to set the timing. Where is zero in relation to this mark. And how the hell do i get the hold down bolt on the distributor off. Are there certain tools or tricks.
Please Help
Chase
1979 F-250 4x4
460 Holley650, MSD OFFROAD, Flex-a-lite fan
C6-B&M Transpack
Dana HD44Front/60Rear 3.73 Limited Slip
35 inch Goodyear Implement Tires
4 inch Skyjacker System
They make distributor wrenches that are offset to clear the distributor head and get underneath to the bolt. Go to your local parts store and ask for one for that engine.. Not expensive, and something you are bound to use again in the lifetime of the engine.
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
