Sponsored by: Real Truck
key pad universal code
Old Jan 30, 2008 | 07:18 PM
Durajunk Killer's Avatar
Durajunk Killer
i have an 04 f-250 and i cant find the universal code for my truck so i can reset it. does anyone know where i can find it or what it is? thanks
Old Jan 30, 2008 | 07:35 PM
pyro2nite's Avatar
pyro2nite
When I got mine I belive the dealer told me if you go to them with proof of ownership they can use the vin to get it. Hope my memeory is correct.
Old Jan 30, 2008 | 07:42 PM
hang10's Avatar
hang10
I believe it's printed on a box located in the "C" pillar, under the trim of the passenger shoulder belt. At any rate, like pyro said, a dealership can obtain it for you. Most the time they don't charge.
Old Jan 30, 2008 | 09:58 PM
swann79's Avatar
swann79
Yup, it's on a sticker on your security module... unfortunately I don't know where that's located on these trucks. It was in the rear cargo compartment of my wife's Expy...
Old Jan 30, 2008 | 10:57 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
04 is like an 07... ish? mine is behind the glovebox i believe.
Old Jan 30, 2008 | 11:54 PM
3000 FPS's Avatar
3000 FPS
Yes texastech_diesel is correct I looked it up and the security module is behind the glove box. As to whether or not the code is there you will have to look but I believe from searching this out before it is. Let us know what you find I for one would like to know.
Old Jan 31, 2008 | 10:12 AM
NorCalBusa's Avatar
NorCalBusa
And the one you will find is not a "universal" one- its just the master one programmed for your truck.
Old Jan 31, 2008 | 12:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If there was a universal code Ford could just leave off the door locks. Everyone would know the universal code and there would be no way to lock the truck.
Old Jan 31, 2008 | 12:58 PM
GregsSD's Avatar
GregsSD
The dealer can hook up their computer to your truck and get the code for you but they will charge you to do that.
You can find it yourself for free, it is printed on the security module behind the dash ( where the transmission tunnel meets the firewall ). You will have to pull back some of the carpet and insulation to see it.
Here is a thread with more info on finding it:
https://www.ford-trucks.com/forums/5...ht=keypad+code
70f250highboy
May 20, 2015 07:58 PM
brbuchanan
May 15, 2015 09:22 PM
69cj
6.7L Power Stroke Diesel
Dec 1, 2014 03:49 PM
92aeroXLT
Aerostar
Nov 25, 2013 08:43 PM
70blue
Sep 3, 2006 06:26 PM
