Sponsored by: Real Truck
Train Horns
Old Jan 28, 2008 | 07:42 PM
TP83's Avatar
TP83
Train Horns
Hi, im looking at some trainhorns and have a couple questions about them.
How much do you actually use them?
Does it seem like you would have liked to put the money elsewhere?
Are they illegal to have on these sized trucks?
And whats the best reaction you have gotten from blasting them?
I cant quite justify spending a few hundred on something i'll only be able to use in my town once.
Thanks for help!
Old Jan 28, 2008 | 08:09 PM
JB666Rock's Avatar
JB666Rock
Hi -- I use mine every day..
It's one of the best "mods" I've done to my truck, to date. It's GREAT.
Illegal? I'm sure, but I haven't been bothered in 7+ months of ownership.
Best reaction?? A pedestrian walking down the road dropped the shopping bags he was holding, hit the ground, and looked up at the sky like there was an air raid about to strike. You had to be there...
Plus, I have mine hooked into my keyfob, so I can blast them up to 1500 feet away , which is even better.. I'm constantly standing 30' from my truck blasting people walking near me..
Thanks for help!
Old Jan 28, 2008 | 08:26 PM
Cecil_Stringer's Avatar
Cecil_Stringer
Yeah I love mine too.
Great mod.... use them nearly daily.
I like hitting them in the parking garage at work send all the car alarms into panic mode. :-)
Old Jan 28, 2008 | 08:28 PM
JB666Rock's Avatar
JB666Rock
I can't fit in the parking garages any more
Old Jan 28, 2008 | 08:31 PM
Wayne64SS's Avatar
Wayne64SS
I have been toying with the idea myself... how much does a setup like that run JB? Does anyone have a bad-*** chain hanging from the headliner to turn them on? lol
Old Jan 28, 2008 | 08:32 PM
Cecil_Stringer
Here's a couple of pics of my set-up:
I mounted the horns under the tool box in the bed.
However, I will likely relocate them when time permits.
Before I tidied up all the wires:
Old Jan 28, 2008 | 08:35 PM
Cecil_Stringer
LOL
Me either, with the exception of the outter thru-path.... it's 8' 4"s high.
Old Jan 28, 2008 | 10:26 PM
94yj's Avatar
94yj
could you give us more info on cost and brand and link if you have it
Old Jan 28, 2008 | 10:32 PM
Cecil_Stringer
Originally Posted by 94yj
what brand of horns are those and where did you get them at and how much they set you back cost wise if you dont mind me asking
I went with www.HornBlasters.com for the set-up.
It's a modified "Conductor's Special" ( http://www.hornblasters.com/products...?item=HB4H5G40 ).
I up-sized the compressor, tank and valve to make it a 200psi system.
I do not remember the cost, but the prices are listed oin their site.
Old Jan 28, 2008 | 10:45 PM
TP83's Avatar
TP83
using the toolbox for the tank and compress seems the be a good idea, to bad i couldnt get my dirtbike in the truck if i put one in there.
cecil, how loud is that setup? im sure it echos out of the bed.
Old Jan 28, 2008 | 11:49 PM
Cecil_Stringer
Rediculous.
Especially under overpasses.
.... and if the back window is open..... it's overly obnoxious in the cab as well.
Old Jan 29, 2008 | 12:30 AM
drmitch's Avatar
drmitch
Where are yall mounting the horns them selves
Old Jan 29, 2008 | 06:03 PM
TP83's Avatar
TP83
i see people mount them on the frame rails, where the spare tire is and sometimes behind the grille.
Old Jan 29, 2008 | 07:12 PM
Cecil_Stringer
Mine are mounted underneath the toolbox in the bed, facing to the rear.
Old Jan 29, 2008 | 07:17 PM
brwolfjr's Avatar
brwolfjr
I mounted a set of grover air horns on the passenger side frame rail with the tank and compressor. I would like to add another 2.5 gal tank and another horn on the driver side.
That will most likely require a second compressor. I would recommend getting a higher psi pressure switch. It will really wake up the horns.
