proper piston ring alignment?
Old Dec 17, 2001 | 01:08 AM
Superdave's Avatar
Superdave
Can someone shed some light on what is considered proper piston ring alignment. I have seen some fuzzy diagrams about alignment, but no clear information or a diagram.
Old Dec 17, 2001 | 07:51 AM
Caddy 53's Avatar
Caddy 53
MOST FORD SHOP MANUELS I'V READ SAY TO STAGG ER THE GAP. I like to use1/3 rotation on each ring.
Be sure to chec for min. end gap .Some top tings have bevel or champher to orienntate.
chuck
Old Dec 17, 2001 | 10:46 AM
jim henderson's Avatar
jim henderson
Yeah, stagger the gaps. Depends on how many rings are used but the key thing to do is make sure none of the ring gaps will line up when the piston is in the bore.
Be especially sure that the oil rings(usually 2 thin ones and one wavey fat one) don't have their gaps lined up, otherwise you will burn more oil than you should.
Also be very sure that the end gaps are as specified. A lot of rings come oversized(so they have enough meat on them to file to fit) and will have no gap at all when installed if you don't gap them first. If you don't gap the rings, they may sieze or break. Been there done that, my idiot friend "the expert" forgot to gap the rings on my first engine. Expensive lesson.
Good Luck,
Jim Henderson
Old Dec 18, 2001 | 01:58 AM
RadarRick's Avatar
RadarRick
TMI
Jun 1, 2016 09:56 AM
fordboy67
Escape & Escape Hybrid
Sep 12, 2015 07:08 PM
Emmett Coffman
Jun 20, 2015 08:13 PM
thegalindo1985
2004 - 2008 F150
13
May 17, 2014 01:28 PM
eddieburnsii
Modular V8 (4.6L, 5.4L)
Jul 22, 2013 11:28 AM
