Best starter?
Old Jan 27, 2008 | 05:34 PM
skittlejr's Avatar
skittlejr
the click could be the starter relay working and not the starter solenoid or it's the starter solenoid kicking but the starter motor is stuck. that would be where the hammer comes into play. testing it is the best idea anyway. i replaced mine two years ago with the basic one from advance auto parts. no problems yet. it was amazing how over time the old starter had been slowly getting sluggish and i didn't notice it, then when the new one was on, it sounded like it was spinning twice as fast.
one note: my starter bolts came loose after a week, i know i tightened them, so i put some loctite on the bolts, which was probably not a good idea seeing as they go into aluminum
Old Jan 27, 2008 | 09:21 PM
johnguc's Avatar
johnguc
I tapped it with the hammer and it clicked a little more but didnt turn
I want to test it at least gonna use jumper cables on it.
I dont think there is a seperate relay.
Leaning toward the DB higher torque starter.
Old Jan 29, 2008 | 01:26 AM
johnguc's Avatar
johnguc
MADVAN are you sure a 1996 van even has the starter relay?
I pulled the battery and looked in the fender well but theres nothing there.
I tried the starter with the jumper cables today and it ran.
But only after I jumped the solenoid.
After that it spun ok off the small solenoid wire.
Old Jan 29, 2008 | 07:25 AM
MADVAN's Avatar
MADVAN
Do you have both batts under the hood?
You might have ambulance package.
Check under the drivers side batt tray.
Bill
Old Jan 29, 2008 | 11:21 AM
skittlejr's Avatar
skittlejr
did you hit the solenoid or the body of the motor? sometimes electric motors get "dead" spots in them (meaning it needs rebuilt or replaced) that you can get them past by hitting the motor with a hammer while applying the voltage either by the key, cables or jumping it with a screwdriver. best thing is to take it off and bench test it or have the parts store do it. sounds like it's bad (either solenoid or motor), assuming that all the connections to the starter from the batts are good and clean?
Old Jan 29, 2008 | 02:04 PM
johnguc's Avatar
johnguc
Well I took it to NAPA it tested bad.
So I ordered the JB starter.
I have the 2 batteries.
I'll check under the driver side batt but I had that out last year and dont remember seeing it.
If its anywhere in there it should be connected to one of the big battery cables right?
Old Jan 29, 2008 | 03:33 PM
FARM69's Avatar
FARM69
Is the SD gear reductions a bolt on to our engines?
Old Jan 29, 2008 | 03:40 PM
tjbeggs's Avatar
tjbeggs
I believe so. but it has only 2 bolts compared to our three. I also think the wiring ends up in a different place but I don't think that is as much an issue.
Old Jan 29, 2008 | 03:49 PM
FARM69's Avatar
FARM69
Cool. Sounds like any issues can be solved with of sodering gun. Wonder why they only went with two bolts instead of three. Oh well.
Old Jan 29, 2008 | 04:36 PM
MADVAN's Avatar
MADVAN
Just being cheap! They saved in machining and a bolt, and a new vender to supply the starter. You have to drill the lug out on the wiring a little bit. It will not fit on the starter. I would rather have the 3 bolt starter. Allthough it may not need it.
Reminds of one of the mini vans. Dont remember which one. On a rearend inpact the door will open and passengers can fly out. All because some smart ars engineer said save the money on the washer. They were recalled to install the washer.
Bill
Old Jan 29, 2008 | 05:23 PM
tjbeggs's Avatar
tjbeggs
Bill
Sounds like fun as long as its not my wife or kids!!
Old Jan 30, 2008 | 08:18 AM
skittlejr's Avatar
skittlejr
what kind of fun it that?!! you need help, tim.
Old Jan 30, 2008 | 10:24 AM
  #28
tjbeggs's Avatar
tjbeggs
No I figured with a helmet it would be fun ride for me! not others. I don't have much excitement in my life right now! I need a good thrill ride. Almost had one this morning. nearly rear ended a cop in a blizzard!!
Old Mar 2, 2008 | 02:13 AM
  #29
mikehm's Avatar
mikehm
I have a 2000 E-450SD and the starter is slow to start turning the engine over, but soon picks up speed and startes the engine fine, and this just started, (good battery and charge, all good connections and cables) the only solenoid is mounted on the starter. There are new starters for about $100. no core, and rebuilt units for $85 to 90 with a core charge. But I found no such thing as a HD starter, except one for a diesel, witch is geared and costs about $500.
Replacing looks easy, its all out in the open.
fyredude
Jul 15, 2016 01:56 AM
Kamden Kramer
Modular V8 (4.6L, 5.4L)
Jun 22, 2016 09:38 PM
wufnu
Oct 19, 2015 05:26 AM
scatgo
Mar 16, 2008 12:12 AM
gtex
Mar 2, 2004 05:52 PM
