smoking
Old Jan 2, 2002 | 05:51 PM
bigtoe's Avatar
bigtoe
smoking
I was always told there are no stupid questions just stupid people, but here's my question to prove my stupidity. I have a 1979 f250 with a 460, it has started blowing smoke out the tail pipe, my questions is. Does this mean my rings are bad or is it i need the heads rebuilt? Some clarification for a moron would be helpful.
Old Jan 2, 2002 | 07:54 PM
Mil1ion's Avatar
Mil1ion
smoking
Does it smoke all the time or just after idling for a while then you rev it up does it smoke?
The latter is usually from worn out decrepid Valve seals.
How much blow-by do you have ?
Pull the PCV valve out of the valve cover and see how much smoke is coming out of the hole.
This smoke usually means the rings are bad.
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 2, 2002 | 08:21 PM
bigtoe's Avatar
bigtoe
smoking
It just smokes after idling for a while. There isn't any smoke coming from the pcv either. If it is just worn valve seal can new heads fix the problem. the truck has good power it just smokes at times.
Old Jan 2, 2002 | 09:02 PM
LxMan1's Avatar
LxMan1
smoking
What COLOR is the smoke ? Black, Blue, White? It could be another problem.
Old Jan 2, 2002 | 09:17 PM
Mil1ion's Avatar
Mil1ion
smoking
Good question LX ,I forgot to ask.
I assumed it was Blue smoke.
If it is , You can just replace the valve seals.
There is a device that hooks up to an airhose(if you have a compressor) that pressurizes the combustion
chamber while you take the valve springs/keepers off and slip the new valve seal on.
With putting the crankshaft in 3 different positions
you can do all 16 valves with minimum turning.
There is another way using rope stuffed in the cylinder too.
* NOTE :
Putting rebuilt heads on a motor with lots of wear can only cause you to take the whole thing apart again because you have now strengthened the top and weaked the bottom end.
Just replace the valve seals and let the whole motor wear evenly.
Dennis
Old Jan 2, 2002 | 10:16 PM
LxMan1's Avatar
LxMan1
smoking
Much better than the ole rope in the cylinder trick. I agree, don't renew the top, or the bottom may pop! Jimmy
Old Jan 2, 2002 | 10:29 PM
bigtoe's Avatar
bigtoe
smoking
How much volume of air do you need to hold everything still?
Old Jan 2, 2002 | 10:57 PM
Mil1ion's Avatar
Mil1ion
smoking
I cranked mine up to 100-120 Psi.
You just leave the air hose attached while you do it.
Dennis
Old Jan 3, 2002 | 09:21 AM
DeGideo's Avatar
DeGideo
smoking
baller9409
Oct 2, 2012 08:53 AM
Tknight85
Sep 27, 2011 07:42 PM
alanc77
Jan 24, 2011 09:44 PM
Country4.2
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 20, 2007 07:48 AM
phonebooth
16
Nov 20, 2004 10:20 AM
