E40D Problem
Old Jan 17, 2008 | 08:11 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
E40D Problem
'94 F350 7.5 E40D
30K miles on "new" rebuilt
At highway speed, the trans will occasionally "let go" and "slam" back into gear. This problem is intermittent - sometimes I can drive 40 miles with no problems, sometimes it will happen after 5 miles.
The unit is due for an oil change. Am I correct in thinking this situation goes beyond oil alone?
The oil does not smell burned, and looks pretty good.
Any thoughts or suggestions?
Old Jan 17, 2008 | 10:04 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The Transmission Range Sensor (TRS) is failing. Replace it.
It's also called the Manual Lever Position Sensor (MLPS) or Nuetral Safety Switch (NSS.)
Old Jan 17, 2008 | 11:27 AM
SteveBricks
FTE Emeritus
Thank you Mark.
Old Apr 26, 2008 | 06:17 PM
tomm211's Avatar
tomm211
I have a '91 that does the same. We have changed all sensors and it has not fixed the problem. I would like to know if you get it fixed.
Old Apr 27, 2008 | 10:09 AM
Mark Kovalsky
Exactly which sensors did you change?
Old Apr 27, 2008 | 10:49 AM
71dusterdan's Avatar
71dusterdan
hey Mark can a chime in with some aod questions. got a 92 g.marquis, reverse and od are out. also nuetral with engine running will continue to pull. turn it off and i can push it back freely. are these problems that will straighten out with a complete rebuild? or do i have potential hard part problems? thank you much. Dan
Old Apr 27, 2008 | 06:36 PM
Mark Kovalsky
Your forward clutch has failed. You need to take it apart to see what needs to be replaced.
Old Apr 27, 2008 | 09:03 PM
tomm211's Avatar
tomm211
if their is a sensor on the truck it was changed. I did find an emerecy procedure posted that would allow you to drive if the solenoid pack went out. Tried that and it worked fine. The pack and torque converter is the only thing that has not been changed.
Old May 9, 2008 | 02:57 PM
tomm211's Avatar
tomm211
e40d problems
Here is the whole story. this is a '91 e-350 ambulance. about 8 months ago while going down the high way at about 80 mph it slammed out of over drive and back in once. the more we used it the worse it got. We changed the TPS and the shift sensor on the side of the transmission, still got worse. We changed the rpm and speed sensors, no change. It seems to be very throtle position sensitive un till the trans warms up, then it gets really bad. We were thinking about changing the selinoid pack, we have another '91 next to this one, not sure if that could be the problem and not sure how to change it anyhow.
Eric Shaw
Jul 28, 2013 09:54 PM
jdr37
Jun 29, 2010 05:13 AM
hodernyf150
Nov 24, 2007 07:11 PM
altonjh1
May 18, 2004 10:37 AM
BOJOFASO
15
Oct 5, 2003 11:27 PM
