blown up c6??
Old May 9, 2008 | 10:09 PM
eclypseballoons's Avatar
eclypseballoons
blown up c6??
1984 460 c6. started to slip in first. then got hard to get reverse. then while coming home from work today, started slipping real bad, then locked into first. i can move the shifter from first through neutral into reverse and it is still stuck in first. i think it is still in first when i shift to park...
help
Old May 9, 2008 | 10:15 PM
monsterbaby's Avatar
monsterbaby
the hard to shift is probably from a bunch of clutch material having gotten into the VB. it means you probably fried the clutches putting all that material into the pan to get into the VB.
Old May 9, 2008 | 10:26 PM
eclypseballoons
Vb?
what is the vb
Old May 9, 2008 | 10:30 PM
monsterbaby
VB = valve body
Old May 9, 2008 | 10:51 PM
eclypseballoons
fried?
so pull it and rebuild it??? or what?
Old May 9, 2008 | 11:11 PM
monsterbaby
I would personally
Old May 10, 2008 | 01:18 AM
eclypseballoons
thanks
thanks will do
dcdave
Nov 30, 2007 01:15 PM
snubber
13
Nov 23, 2004 05:39 PM
Rick X
Apr 7, 2003 11:24 PM
dolphin
1978 - 1996 Big Bronco
Jul 28, 2000 08:12 PM
