e40d problem
Old Nov 19, 2007 | 04:13 PM
hodernyf150's Avatar
hodernyf150
Angry e40d problem
i got a 94 f150 5.8 liter and i got a tranny problem. the tranny will drop out of gear while it is in drive. and it will not shift sometimes to. it dose not do it all the time just when it warns up sometimes, it will go away and come back in a week or so. any idea
Old Nov 19, 2007 | 04:15 PM
Skandocious's Avatar
Skandocious
How's your fluid level and color? Start the truck and warm it up by driving around for 15 or 20 minutes, then check the fluid with the engine running and the tranny in neutral. Should be a nice pink-red color. Also smell the end of the dipstick to see if it smells burnt.
Old Nov 19, 2007 | 04:19 PM
hodernyf150
the fuild is nice and red and the level is all good
Old Nov 19, 2007 | 04:47 PM
lostin90s's Avatar
lostin90s
Its the shift sensor "MPLS" (I think) . It acts like it drop into nuetrall right? then bangs back in. Or you will be driving along with no stress (down grade ) And will act like Neutral for second. I don't know price of new ones. As SKandocious can tell you I got parts hid every where . So I reuse things.
The the sensor on the shaft shift linkage hooks to .
Block wheels (you will be shifting tranny trying to get things loose. )
Unhook cable ,
Loosen retaining nut on shift arm ,
Pay attention to how sensor is positioned on slots .(I never had any trouble but there is some adjustment there. )
Remove 2 10 MM (I think ) Bolts .
It will come off. you can swap in less than 15 minute without jacking up truck.
Please remember to take cable off first . I messed mine up trying to unhook with on
Good luck if I had a spare I'd give it to you to check it out . Good luck
Old Nov 19, 2007 | 05:52 PM
Skandocious
I posted instructions for adjusting the MLPS on the following thread:
https://www.ford-trucks.com/forums/6...ps#post5128529
Might want to try that before spending the money on a replacement
Old Nov 19, 2007 | 06:01 PM
hodernyf150
is that on the tranny by the shift cable
Old Nov 19, 2007 | 06:02 PM
Skandocious
That is going to be on the left side of the tranny, right at the center.
Old Nov 19, 2007 | 06:06 PM
hodernyf150
ok thank you very much what are some good performance mods for the 5.8
Old Nov 19, 2007 | 06:22 PM
lostin90s's Avatar
lostin90s
Chris is right about trying adjustment .I should have posted that I never was lucky enough for it to work . For more than week any way. Hope it works for you.
Its the problem with having extra parts . If can test it I do . other wise its dig in a box . Later
Old Nov 24, 2007 | 06:07 PM
bronco-man's Avatar
bronco-man
I Had The Same Problem With My E40d 1990 351 Windsor , I Took Off The Mlps ,used Air Pressure To Clean Grease & Dirt, Cleaned It With Electrical Parts Cleaner ,install It Back On Trans & Adjusted , It Drove With No Problems After That.
Old Nov 24, 2007 | 06:33 PM
lostin90s's Avatar
lostin90s
I'll give that a try some day while milling around the shop. I have 2 "bad" MLPS down there. Later
Old Nov 24, 2007 | 07:11 PM
rednwhite92's Avatar
rednwhite92
I had the sensor go out on my truck and it did the exact same thing, me not having a clue took it to the dealer and it was roughly 600 dollars to diagnose replace and adjust the new one.
Shampboys 4
1997 - 2003 F150
Oct 22, 2021 10:59 AM
79ford302
Oct 2, 2010 11:36 AM
bmacky14
1978 - 1996 Big Bronco
17
Mar 1, 2010 10:42 AM
javi2001
Jun 14, 2004 04:08 PM
blue93f150
16
Jan 7, 2004 03:35 PM
