HX Crossover Mod
Old Jan 16, 2008 | 01:01 PM
  #61
rugermack's Avatar
rugermack
Originally Posted by just another truck
Thank you, so the return is suggested, but not needed?
A CC kit ran me $119 with HXP hose
A regulated return kit is $549
Theres alot more to the regulated kit, and i'm sure it works better. If your just going to stay with stock injectors and HPOP, the CC kit should be fine. If you plan to make big HP with bigger injectors and oil pump, then maybe the regulated kit is for you. I just wanted to smooth out the motor, and I do anything that helps with the life of the motor and its parts. I also shimmed the regulator for a little increase in fuel pressure.
Old Jan 16, 2008 | 02:08 PM
  #62
just another truck's Avatar
just another truck
sorry, when I said regulated return, i was refering to exactly what you said joe, the orfice installed in the T, but that is the part I dont understand, why it is needed..
Old Jan 16, 2008 | 02:15 PM
  #63
Izzy351's Avatar
Izzy351
If you don't put some kind of restriction after the heads, there will be too much flow back to the tank which means lower pressure. The orifice allows some flow out of the heads so any air making past the bowl can flow through the orifice back to the return line, but not so much flow that there's a pressure drop.
Old Jan 16, 2008 | 03:12 PM
  #64
bdrummonds's Avatar
bdrummonds
Originally Posted by rugermack
Th HXP and CC kit are good together. The CC kit does have the "T" in it for the return, or atleast my kit did. A regulated return is different than a CC kit. A CC kit isn't regulated, it just ties the fuel rails in one head to the other, and helps cylinder 8 with fuel pressure after cylinder 6 fires.
The cc-kit IS regulated. it is regulated by the orifice fitting that is between the return T and the return line. A different size orifice will give you different fuel pressures(at least when you go as far as I did and delete the fuel bowl)
Really, you can make your own regulated return and fuel bowl delete very inexpensively.
1. CC-Kit for the return side. $119 or less if you source your own parts
2. 5/8" fuel line from pump to front of engine (get the parker just like the cc-kit, as it is fire rated hose. $20-$30
3. delete fuel bowl.(free)
4. 5/8" T from #2, and a line to the front of the drivers side head fuel port, and a line to the PAX rear fuel port, or you could feed both front fuel ports, and return out of the rear fuel ports. $40 for various JIC to NPT fittings
your regulation would be adjusted with the size of the orifice at the T off the return side.
5.You will need to mount a remote filter assembly on the frame $50
Remember, you will probably only adjust it once or twice then just run it.
the whole thing can be done for $240 or less if you source the hose and fittings for the cc-kit.
The fuel system on these PSDs is not complicated. feed one side of each head, and drain the other side of the same head, and then run the drain into a T with an orifice,(this creates pressure, and bleeds air) back to the tank. the T in a stock set up is the fuel bowl
See my gallery for a pic of it done under my hood. See pics 19,20,21 , now I went one step further and got a 95GPH FASS pump to replace my failing stock pump, but if you stock pump is good then you won't need it.
Old Jan 16, 2008 | 03:26 PM
  #65
rugermack's Avatar
rugermack
But not adjustable like the regulated kit would be the difference. I already have the CC kit.
Old Jan 16, 2008 | 03:47 PM
  #66
bdrummonds's Avatar
bdrummonds
It is adjustable, just use a different size orifice. the orifice fitting is a screw on fitting that attaches to the T, and they can be had for as little as $2 or less, they are reusable so if you invest in a couple, you can adjust to your hearts content.
the one that came with the CC-kit is the one that I am currently using, and it is holding 75psi at idle, and 68psi at WOT with my 120R setting for my DP tuner. I dont have a fuel bowl so mine is regulated by the orifice, not the FPR on the fuel bowl
Snowking
34
Jun 26, 2021 04:34 PM
Hyperactive460
Oct 21, 2015 06:49 AM
Hyperactive460
Sep 17, 2015 07:55 AM
zak8tac
Colorado Chapter
Nov 1, 2009 11:12 AM
