HX Crossover Mod
Old Jan 15, 2008 | 11:23 AM
  #31
rbaker6336's Avatar
rbaker6336
Originally Posted by PaysonPSD
Would shortening the return line have the same effect? I have never heard that mentioned. Would it have an adverse effect? Does the return line have to be immersed in the fuel?
only reason I can see for return going to the bottom is to heat the fuel quicker
all the older diesels just had a short tube for return
Old Jan 15, 2008 | 11:25 AM
  #32
rugermack's Avatar
rugermack
Originally Posted by Kwikkordead
If you miss this step all your work will be for nothing. That goes for all the quick connects between the fuel tank and the fuel pump inlet. The fuel return does not need to be messed with, nor does anything between the fuel pump and the engine. Just the plumbing between the fuel tank and the fuel pump inlet. The air gets into the fuel stream via those quick connects because that part of the system is under a partial vacuum and it gets sucked in there. Get rid of them and use FI rated fuel hose with two hose clamps per end. If there is not enough room for two, no big deal. I simply like the redundancy for the best seal.
Thanks Izzy and Kwik, I didn't know about the quick disconnects. I'll eliminate them also. I'm waiting for my WW and new tubes for the intake. maybe I'll make it a long weekend getting this stuff done.
Old Jan 15, 2008 | 11:26 AM
  #33
rugermack's Avatar
rugermack
Patrick-
The fitting right before the fuel pump should be removed because they will at times suck air into the fuel system. The whole reason for this MOD is to keep air out of the fuel system. My .02 cents
Thanks. didn't know that.
Old Jan 15, 2008 | 11:31 AM
  #34
PaysonPSD's Avatar
PaysonPSD
Ray,
Thanks for the input.
I was thinking why lengthen the return line when you could just shorten it. Let it return way above the pickup and the air would rise, not sink. I'm sure the older diesels didn't have a problem when the fuel level dropped below the end of the return line.
Old Jan 15, 2008 | 12:11 PM
  #35
Izzy351's Avatar
Izzy351
I understand why you would want to extend the fuel return line to get it away from the pickup to lessen the chance on introducing air at that point. Would shortening the return line have the same effect? I have never heard that mentioned. Would it have an adverse effect? Does the return line have to be immersed in the fuel?
You'll understand when you get in there. You definitley don't want the fuel just dropping down in from the top that's very bad. Possible static discharge. Plus it will drop right on the pickup when the tank gets low, letting air back under the pickup foot.
The reason for the Z-shaped line is to get the return as far from the pickup as possible, and to clear the float. I think one of the guys used rubber hose back the other direction, but I think he wished he did with all SS after thinking about it.
Old Jan 15, 2008 | 12:33 PM
  #36
rbaker6336's Avatar
rbaker6336
[QUOTE=Izzy351] Plus it will drop right on the pickup when the tank gets low, letting air back under the pickup foot.
QUOTE]
if an air bubble did drop down and not float and get to the pickup you would already be out of fuel and it wouldn't matter anyway
Old Jan 15, 2008 | 12:53 PM
  #37
PaysonPSD's Avatar
PaysonPSD
Ideally, if the In Tank-Pre Pump MOD does what it is supposed to do there should be no air in the return line. If there is air in the return line then the MOD doesn't work. Is this an accurate statement? I did say ideally.
Old Jan 15, 2008 | 01:01 PM
  #38
Kevinpmac's Avatar
Kevinpmac
True on one hand, but I would not want hot fuel dropping down on my supply tube when fuel gets low. Extending the return out of the way seems like a no brainer for not much extra expense or effort.
Old Jan 15, 2008 | 01:32 PM
  #39
PaysonPSD's Avatar
PaysonPSD
Thanks Guys for all the input. I always like different points of view. I like to
play the Devil's advocate in most discussions to get the different points a view.
  #40
Kwikkordead's Avatar
Kwikkordead
I have my fuel return pointed a long ways away from where it enters the pickup.
It's the long horizontal steel line that goes along the bottom of the picture.
Never mind the fuel pump attached to the end of it. I'm just showing my pickup to illustrate a good way to route the fuel return line.
Old Jan 15, 2008 | 01:44 PM
  #41
rugermack's Avatar
rugermack
Damm !! thats a big one!! Looks like a good idea.
Old Jan 15, 2008 | 02:00 PM
  #42
Kwikkordead
Hands down it is the best mod for the fuel system that you can do. The entire fuel line is pressurized.
Old Jan 15, 2008 | 02:05 PM
  #43
rugermack's Avatar
rugermack
I'd have to agree on that. Of course adding the CC kit, HXP and regulator shim does finish it up nice.
Old Jan 15, 2008 | 02:11 PM
  #44
PaysonPSD's Avatar
PaysonPSD
Dan,
I was going to go searching for that pic and came back here and found that you posted it. Big Thanks. This time I saved it off the post. Hope you don't mind.
Old Jan 15, 2008 | 02:56 PM
  #45
brian42's Avatar
brian42
Veteran: Navy
I installed the KCM SS HPX and the in-tank/pre-pump mod (both from ITP Diesel) over the last couple of weeks. The HPX made it a smoother idle (especially when cold) and the in-tank mod quieted the injectors down. It's still all kinds of loud (people still turn their heads thinking the garbage truck is coming) but it's not as rough. At idle the diesel rattle is still very noticable, but more from under the engine than on top (no more pumping air through the injectors).
No real SOTP change except my black cloud is bigger when I get on the freeway now. All in all well worth the $200 or so I spent to extend my injector life.
