6673??
Old Mar 6, 2008 | 11:27 PM
  #46
superduty4x4's Avatar
superduty4x4
Mine probably used to do that too!
Old Mar 7, 2008 | 08:14 AM
  #47
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by superduty4x4
Does the 3" PVC fit tight inside the filter? I thought it needed to be 4" OD, and the PVC and ABS I found in town was NOT 4" OD.
Chase, the 3" pvc dwv coupling fit just right, there is a little bump on one end of the coupling that needs to be ground down to make it smooth. They are cheap to buy.
Old Mar 7, 2008 | 08:18 AM
  #48
Markadeck's Avatar
Markadeck
Gone, but not forgotten
It's a shame some of y'all have to use a 3" reducer, you're cutting down 25% of the flow doing that.
Old Mar 7, 2008 | 09:52 AM
  #49
superduty4x4
Okay, now I smell what you're stepping in Rick- you used a straight coupler for 3" pipe in order to get the 4" OD needed... wish I had thought of that while I was in town yesterday! I'm going to call a local tire shop today to see if they have any 4" tubing laying around, if not my exhaust will be here today hopefully and I should have some leftovers. Hopefully my gauges will be here today or tomorrow too
Old Mar 7, 2008 | 09:56 AM
  #50
miller_feed
The outside of the 3" coupling is 4".
Old Mar 7, 2008 | 10:05 AM
  #51
Markadeck's Avatar
Markadeck
Try an interesting experiment. Get 2 one inch water hoses, say 10 feet long. cut one in half and put in a 3/4 inch 6" long piece of copper. then get a 5 gallon jug and see which one fills up faster. You'll be amazed at the results. I learned this from my street racing days when dealing with exhaust diameter's.
Old Mar 7, 2008 | 10:47 AM
  #52
Mat J's Avatar
Mat J
will one of these filters work good on a gas 460 too?
Old Mar 7, 2008 | 10:50 AM
  #53
Markadeck's Avatar
Markadeck
Ya got me. Post a photo of your engine compartment and let us look at it.
Old Mar 7, 2008 | 11:08 AM
  #54
miller_feed
I understand what you are saying Mark. Look at where the intake hose goes into the turbo. It is smaller then 4". I don't think my engine is starving for air.
Old Mar 7, 2008 | 11:10 AM
  #55
superduty4x4
Not likely since the 460 has the twin intake tubes, though I don't remember if it's a single piece at the airbox anymore.
heady1
19
Apr 9, 2018 06:51 PM
jerry_s
76
May 3, 2017 01:55 PM
Rikster-7700
Feb 26, 2016 08:47 AM
petemcl
Feb 22, 2016 09:43 PM
truckdrivermn
Jun 18, 2014 09:50 AM
