Sponsored by: Real Truck
repeating clunk when turning
Old Jan 13, 2008 | 09:58 PM
Vegas04's Avatar
Vegas04
hello to all. I searched and read a few threads about clunks, but I still have to run this by some people...
My buddies 2000 F-250 4x4 has a clunk that repeats over and over again when turning right as well as when turning left. I would think that a bad tie-rod end or steering linkage could cause a single clunk but if it repeats over and over again I though it must be either the axle u-joint(s) or the hub. It turns out that the u-joint in the axle is not replaceable and it doesn't even have a grease fitting. Any ideas- could it be a rod end? By-the-way the truck has 293,000 miles on it and there is no play up-and-down at the knuckle. Thanks in advance.
Old Jan 13, 2008 | 11:45 PM
Vegas04's Avatar
Vegas04
please, anyone?
Old Jan 14, 2008 | 08:25 AM
cyclenut80's Avatar
cyclenut80
Sounds to me like the u joints are dry and seized. They are replaceable but you have to tear the whole front end apart to do it. I just did mine when I did the ball joints and one u joint was totally frozen. I had similar symptoms before I did the overhaul.
Old Jan 14, 2008 | 08:34 AM
Monster-4's Avatar
Monster-4
Is the 4X4 electronic shift on the fly (ESOF)? If so he might still be in 4WD even if the switch is set to 2WD.
Old Jan 14, 2008 | 11:13 AM
redford's Avatar
redford
FTE Leadership Emeritus
Does it only do this when the wheel is turned fully to the right or left?
Old Jan 14, 2008 | 06:10 PM
1toptech's Avatar
1toptech
If the front axles are turning (hubs not unlocking) it is a normal sound caused by the axle joints. He just needs to repair the hubs so they will disengage.
Old Jan 14, 2008 | 06:24 PM
thatsme's Avatar
thatsme
Yep, hups are not unlocking. My 99 f-250 had the same issue. If your hubs are hard to turn, you could dissassemble an clean them, but I'm here to tell you they won't last long. I ended up replacing 1 of the hubs. that took care of it.
Old Jan 14, 2008 | 06:58 PM
Chance_Thomas's Avatar
Chance_Thomas
Mine did this and it was the front left hub assembly.
Old Jan 14, 2008 | 10:46 PM
1985IDIFORD's Avatar
1985IDIFORD
Mine makes a similar noise, with 120k. the hubs are unlocked-so im thinking u-joints. I will also note that the sway bar bushings have about 1/16th of noticable play, so when I replace them i'll let you know if it helps.
Old Jan 14, 2008 | 11:34 PM
G BOBKA's Avatar
G BOBKA
Had basically that same noise in the front of my truck, and I found out that it was the sway bar. Check the sway bar bolts, and don't be afraid to tighten them up. They can take a lot. I thought it was the hubs, but it was a sway bars. Hope this helps
MDSuperDuty
Dec 5, 2011 07:37 AM
Jayme Duty
Feb 1, 2011 12:41 PM
1954F250
Oct 22, 2006 07:39 AM
johnanderson
Dec 4, 2003 12:06 AM
ftrucktough
1978 - 1996 Big Bronco
Feb 4, 2003 11:29 PM
