95 4wd frond end clunking
1995 F150 4wd, manual hubs
When I lock in the hubs and have the transfer case in 2wd, I hear a clunking in the front drivetrain when I turn in a circle at full steering wheel lock. The U-joints on the axles are only 2 years old.
I took out the front drive shaft and drove the truck with the hubs locked in and there was no noise.
I figured it had to be the front drive shaft so i replaced the U-joints in the front drive shaft and re-installed it.
When I test drove the truck, the noise was back.
Any ideas what could cause the noise. I am stumped because it seems I have ruled out all of the U-joints.
Thanks
1954F250
Thanks
1954F250
I think its just because you have the hubs locked in. My '03 SD does the same thing when I have the hubs locked and TC in 2wd. I lock the hubs for use on the jobsite and if I leave the job to get a coffee or something it does the same you mention on dry pavement when the wheel is turned hard, and the BJ's are new. So it may not be a problem at all. Just my .02
CG-Lock Racer
01-31-2013 09:46 PM
