boost #S
Old Jan 7, 2008 | 07:12 PM
Ftree50's Avatar
Ftree50
boost #S
just got my guages installed today. getting around a max of 16lbs of boost with the red vac line on and 23 with it off. was wondering if my wastegate is going or something else
Old Jan 7, 2008 | 07:22 PM
ron's power stroke's Avatar
ron's power stroke
is the air filter clean??look for soot on the up pipes behind the turbo..also check all boots for loose clamps or splits..your boost is a little low..but not to bad..
Old Jan 7, 2008 | 07:25 PM
mybigredford's Avatar
mybigredford
Originally Posted by ron's power stoke
look for soot on the up pipes behind the turbo...
what do you do if you see soot on the up pipe, i think i may have one leaking, i will try and post a picture, is there a gasket to replace?
Old Jan 7, 2008 | 07:30 PM
Vader0121's Avatar
Vader0121
16 lbs is stock rating at least for mine, and when I did the wastegate mod it brought it to 23 lbs (before I got my DP!). Maybe your truck is a later year (things changed middle of 99). But I trust Ron's wisdom and of course would do the boot check etc.
Old Jan 7, 2008 | 07:32 PM
ron's power stroke
there is a donut for each pipe up behind the turbo..they just bolt to manifold down below...if the pipes are good..you need all new bolts and 2 donuts...if funds allow go to bellowed up pipes..
Old Jan 7, 2008 | 07:34 PM
Pocket's Avatar
Pocket
Is your truck stock otherwise? If so, that's perfectly normal.
Old Jan 7, 2008 | 07:39 PM
ron's power stroke
18 to 20 on a stock is normal i thought..sorry if i steered you wrong...
Old Jan 7, 2008 | 07:47 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
vader, With your setup and dp on 80econo what is your boost numbers? also what does the wastegate shorten rod do and what is the boost fooler??
Old Jan 7, 2008 | 08:06 PM
Ftree50's Avatar
Ftree50
dont know why i didnt say what i was driven. i have a non chipd 1999.5.
Old Jan 7, 2008 | 08:10 PM
Vader0121's Avatar
Vader0121
I'm ashamed to say that I haven't even looked at the boost guage since putting the DP on but it has got to be 20-25 lbs (all by the seat of my pants) my 80 econ makes awesome power. The rod shorten makes the blow off stay closed longer or completly depending on how short you go. And the boost fooler is a limiting device the hides actual boost from the MAP it's adjustable as well (the computer will de-fuel at 22-25lbs for protection)
Old Jan 7, 2008 | 09:53 PM
Pocket's Avatar
Pocket
16-18 is pretty normal, depending on where you live (altitude). Highest I ever hit without a chip was 18 lbs of boost, and I was really getting on it hard going uphill to make that happen.
officer131
Feb 6, 2008 07:53 PM
64ponton
Dec 5, 2007 08:47 PM
sean23johnson
44
Jan 9, 2007 10:54 PM
Gage2502
Modular V10 (6.8l)
Feb 25, 2006 11:42 AM
Banshee Ben
Nov 10, 2005 07:45 PM
