Sponsored by: Real Truck
boost
Old Dec 2, 2007 | 10:09 PM
64ponton's Avatar
64ponton
need help increasing boost
I got a manual boost control but it is not increaseing the boost can anyone help me increase the boost on my 2000 7.3psd
Old Dec 3, 2007 | 07:15 AM
Pocket's Avatar
Pocket
Manual boost control? There is no such thing for a 7.3L PSD. If you want more boost, you have to add more fuel via chip or tuner.
Old Dec 3, 2007 | 08:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would like to know what you put on your truck. Manual boost control???????
Old Dec 3, 2007 | 08:41 AM
BillyBob69's Avatar
BillyBob69
I agree...I haven't never heard of a manual boost control for the 7.3 PSD. Is there something aftermarket installed on you truck?
Old Dec 4, 2007 | 10:34 PM
64ponton's Avatar
64ponton
forgive me for my stupidity I'm new at this turbo stuff i am a bottle feed baby so any info to help me is greatly appreciated
Old Dec 5, 2007 | 07:59 AM
BillyBob69's Avatar
BillyBob69
I think it is more of a matter of what it is you are talking about? Alot of parts have different names depending on what part of the world you are from....Can you describe what it is that you are wanting to adjust?
Old Dec 5, 2007 | 09:17 AM
tex25025's Avatar
tex25025
Could he be talking about the boost annihilator that is supposed to override the factory cap on the boost that the turbo generates?
Old Dec 5, 2007 | 08:04 PM
64ponton's Avatar
64ponton
hellow billy bob. yes tex i think that is what the ford tech was talking about i was told that it would release the pressure if the wastegate fails. is this correct and again thanks for all of you helping me with info
Old Dec 5, 2007 | 08:19 PM
ghunt's Avatar
ghunt
Uh, your truck doesn't have a wastegate.
I'd like to know what the hell this boost controller is hooked into.
Old Dec 5, 2007 | 08:25 PM
64ponton's Avatar
64ponton
i took the boost controller off because it did not work it does have a wastegate but the ford tech said that it had a back up valve incase the wastegate failed that is run through the ecm.
Old Dec 5, 2007 | 08:28 PM
Pocket's Avatar
Pocket
Yes his does. 99-03 Superduties with the 7.3L Powerstrokes have wastegated turbos. Vans equipped with the 7.3L PSD's have non-wastegated turbos.
BTW, his questions are being answered in a thread in the 7.3l Diesel section.
Old Dec 5, 2007 | 08:29 PM
ghunt's Avatar
ghunt
edit: OK then, I stand corrected. I thought all 7.3 powerstrokes were non-wastegated, all the ones I looked at sure didn't look like they had one.
Old Dec 5, 2007 | 08:30 PM
Pocket's Avatar
Pocket
There is no backup valve either. I don't know what your Ford tech was trying to explain to you. Maybe he was talking about the wastegate solenoid? That's nothing more than a solenoid that diverts airflow to the wastegate actuator to push it open. That's the only extent of control the PCM has over the wastegate.
Old Dec 5, 2007 | 08:31 PM
Pocket's Avatar
Pocket
The '94-97 Powerstrokes don't have a wastegate either. That might be what you are referring to.
Old Dec 5, 2007 | 08:35 PM
ghunt's Avatar
ghunt
Ahh, maybe. I test drove a '97 and it was definitely non-wastegated, and I drove a '99 and it also looked to me like it didn't have a wastegate, but I guess I didn't look close enough.
