Rev-Limiter
Old Dec 31, 2007 | 07:57 PM
country2's Avatar
country2
Rev-Limiter
This evening I got on my truck hard for the first time since I have owned it. It was in 2nd gear and I was watching the boost (about 22 psi ) and when I looked at the tack it was in the red about 3700 rpm if I remember correctly. I thought that the rev limiter would hold it at red line. Do you think it hurt anything??? I won't be doing that again.
Old Dec 31, 2007 | 10:16 PM
medhvac's Avatar
medhvac
I dont think diesels have rev limiters, but they do have governers that keep the rpms from getting too high, just like a rev limiter does...
Old Dec 31, 2007 | 11:05 PM
twags6's Avatar
twags6
The PCM controls how high you can rev the engine by limiting the fuel (same as the speed limiter at 94 mph). 3400 rpm's should be the redline. Now when you shift, it can rev higher because you have the engine loaded and when the trans shifts, it unwinds a bit and revs higher.
Old Jan 1, 2008 | 12:09 AM
jtharvey's Avatar
jtharvey
Won't hurt a thing.
Old Jan 1, 2008 | 12:20 AM
twags6's Avatar
twags6
How high can these engines actualy rev before some damage starts?
Old Jan 1, 2008 | 01:04 AM
SolidGround's Avatar
SolidGround
Depends what you're working with.
The stock valve train tends to 'float' around 3700.
Old Jan 1, 2008 | 06:26 AM
country2's Avatar
country2
I thought right before it shifted I felt it dump fuel. So you do not think that short burst would hurt these engines?
Old Jan 1, 2008 | 06:39 AM
ron's power stroke's Avatar
ron's power stroke
diesels are built to run at WOT all day long.. if the truck feels the same as it did before this..you didnt hurt a thing..worse that happend was you cleaned out some cobwebs..
Old Jan 1, 2008 | 11:52 AM
jtharvey's Avatar
jtharvey
What you may have felt was the PCM cutting the injector pulse width (how long the injection shot it) back, and may have felt like a fuel dump. As you approach redline, the PCM cuts it back, which you can see as popping and stuttering, typically on initial launch, in some of the pulling videos out there.
cecilt
Jan 13, 2015 08:57 PM
Nickf1989
Jan 1, 2013 08:53 PM
zmock8
Apr 13, 2009 02:50 PM
suburbanM3
44
Sep 12, 2008 09:18 AM
treb
1983 - 2012 Ranger & B-Series
Jun 6, 2003 11:19 AM
