O K, starting prob not fixed
Old Dec 26, 2007 | 09:10 PM
  #31
tjbeggs's Avatar
tjbeggs
But thick oil also seals worn pumps. Think IPR o-ring. Cold start, hot no start. I think this is the common cold weather romp though. Either plug it in, live with it, or get thinner oil.
Old Dec 26, 2007 | 09:11 PM
  #32
2 stroke man's Avatar
2 stroke man
ya i know. im asking location of this LPOP
Old Dec 26, 2007 | 09:13 PM
  #33
tjbeggs's Avatar
tjbeggs
On the crank/front cover behind the crank pulley.
Old Dec 26, 2007 | 09:17 PM
  #34
Action4478's Avatar
Action4478
Look here.....
Old Dec 27, 2007 | 06:38 AM
  #35
WALJON's Avatar
WALJON
If I don,t change my oil from 15/40 when it gets cold mine does the same thing,in the cold weather I use 10/30 and even with the 10/30 it still starts hard some mornings and romps like tj is talking about even when pluged in,did you by any chance check the fuel filter heater?
Old Dec 27, 2007 | 08:03 AM
  #36
2 stroke man
ya, checked it last time i changed filter. i think im gonna go out now and clean fpr screen for the heck of it, and check heater again, and make sure heater is plugged in good. be back in a bit
Old Dec 27, 2007 | 08:35 AM
  #37
2 stroke man
well, its the fuel heater. the sorder points are broke. my old man told me that the reason it wouldnt start good was running it on 90 hp all the time. said i had prolly melted something lol. now he says i probably got it hot enough from being turned up to melt those sorder points. he aint very realistic. hes mad cause my old truck wil run with his new one he just traded for. lol.
Old Dec 27, 2007 | 09:59 AM
  #38
MagKarl's Avatar
MagKarl
Do a search of fuel heater. Remove the fuel filter and standpipe (LH threads) and get that broken heater out of there. Unplug it on the inside. Check your fuses, if the heater shorts out, it won't start. Everyone here says you don't need that heater.
Old Dec 27, 2007 | 03:01 PM
  #39
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Or you can upgrade it, if you REALLY need it.
http://www.thedwilsons.com/powerstro...eater_Mod.html
Old Dec 27, 2007 | 03:46 PM
  #40
MikeFromShiloh's Avatar
MikeFromShiloh
My truck's fuel heat was gutted when I bought it. I have not had any problems with the cold weather (live in western KY about 3 hours west of Bowlin Green). 2 Stroke and I have very similar weather.
A bad HPOP was mentioned. I am like TJ. A bad pump would cause far more trouble when hot than cold.
The LPOP is located behind the harmonic balancer. Looks like the factory oil pressure gauge would tell if this was the problem.
I dont have any new ideas what the problem is.......
mxdadof2
13
Mar 30, 2010 03:35 PM
thosegrays
May 6, 2009 12:08 PM
cj2028
20
Jan 21, 2008 11:22 PM
2 stroke man
Dec 29, 2007 07:06 PM
