Door Tag Decode
Old Dec 14, 2007 | 10:36 AM
gritsngumbo's Avatar
gritsngumbo
Door Tag Decode
NumberDummy:
Can I get a decode? Thanks.
F10JK566568
114 M F100 481 F 12
5000 114 3600 64
Old Dec 14, 2007 | 11:19 AM
bertha66's Avatar
bertha66
F10-61-66 F100
J-61-64 223cid engine
K-Kansas City
566568- made in Jul 64
M-Corintian White
F100-2wd 61-66
Trans-F-62064 4sp
12axle-3:89
Thats all that I have for a break down in my listing, I sure someone else will have the rest.
Old Dec 14, 2007 | 04:32 PM
camperspecial65's Avatar
camperspecial65
Trans code F= warner T98A
481= Lt Beige crush vinyl and lt Beige rib vinyl
81 is a conventional cab
Old Dec 14, 2007 | 05:16 PM
runinbear's Avatar
runinbear
can i get i decode
hey bertha66, will you decode my info please
F10YD803722
129 JN F100 E81 G17
D5000 172 4000 61
thank you jeff
Old Dec 14, 2007 | 07:34 PM
mtflat's Avatar
mtflat
runinbear - check your post for info
grits - the 114 is wheelbase in inches, my book shows color as wimbledon white, and the last line is gvw in lbs, HP @ rpm, and last is dso code for New Orleans
Old Dec 16, 2007 | 04:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by gritsngumbo
NumberDummy: Can I get a decode? Thanks.
F10JK566568 114 M F100 481 F 12
5000 114 3600 64
F10 = F100 2WD
J = 223 I-6 1V
K = Kansas City Missouri Assembly Plant
566568 = 1964
114 = 114" Wheelbase
M = Wimbledon White
F100 = F100 2WD / 5,000 lbs. GVWR = Gross Vehicle Weight Rating.
481: 4 = Light Beige Crush Vinyl & Light Beige Rib Vinyl / 81 = 81A Standard Cab.
F = Borg-Warner T-98 4 Speed
12 = Ford 9 Inch Rear Axle / 3.89-1 / Non Limited Slip / 3,300 lb. Rear Axle Capacity
5000 = 5,000 lbs. GVWR
114 HP @ 3600 RPM
64 = New Orleans Ford District Sales Zone = Where the original selling dealer ordered the truck from.
Color Code M: Corinthian White used 1960-1963 / Wimbledon White used 1964/ (into the 1990's).
(1956/59, the color code for Corinthian White was E.. In 1955 E was the color code for Snowshoe White.)*
It's not GVW...but GVWR = Gross Vehicle Weight RATING.
What Ford says is the maximum weight the truck can safely carry. The weight of the truck, driver, any passengers and cargo should not exceed 5,000 lbs.
*Trivia: There were no Ford trucks painted white till 1955, and no FoMoCo cars were painted white till 1952. Problems mixing the pigment was the reason.
This was not only true for Ford, but for all the auto manufacturers. The only vehicles painted white prior to the 1950's were some Custom bodied cars (Packard/Cadillac/Lincoln/Duesenberg etc.) made in the 1930's, and a few Professional Cars = mostly Ambulances and Flower Cars.
Old Dec 16, 2007 | 04:57 AM
NumberDummy
F10YD803722
129 JN F100 E81 G17
D5000 172 4000 61
thank you jeff
You asked to have this VIN decoded in another thread, the info is there.
Old Dec 16, 2007 | 11:05 AM
gritsngumbo
Thanks for the info!
Old Dec 17, 2007 | 01:07 PM
bertha66's Avatar
bertha66
F10 = F100 2WD
J = 223 I-6 1V
566568 = 1964
M = Wimbledon White
114 HP @ 3600 RPM
My referance says the M code for Corinthian White was run 61-64 and 65-66 the M code was for Wimbledon white. His truck being a 64, that is why I went with Corintian.
Old Dec 17, 2007 | 02:42 PM
mtflat's Avatar
mtflat
quote: "It's not GVW...but GVWR = Gross Vehicle Weight RATING.
What Ford says is the maximum weight the truck can safely carry. The weight of the truck, driver, any passengers and cargo should not exceed 5,000 lbs."
Sorry, I'm just not **** retentive enough to worry about the difference. Means the same thing in my world..............
hello113
Oct 29, 2016 11:37 AM
1965GTFB
Apr 24, 2015 03:13 PM
MCD46
Nov 14, 2013 08:44 PM
RedDiesel71
Sep 16, 2013 05:53 AM
davewave649
May 8, 2011 12:52 PM
