new member
Old Dec 15, 2007 | 09:19 PM
texasborn's Avatar
texasborn
new member
hello, been reading this board a while now. found some interesting stuff. im looking at a 65 f100 4x4, is it possible to convert to power steering? what about power disc brakes? what kind of automatic trans could be put in it? the truck has a 352 ci. thanks for your help
jason
Old Dec 15, 2007 | 09:46 PM
Heath62's Avatar
Heath62
Trailering
As far as I know, LMC magazine can get you a power steering unit for this truck. I can get one for my '62. Why would you want to go to disc brakes? Drums offer more contact area.....Why auto tranny?
Old Dec 16, 2007 | 05:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are dozens of FTE sponsors that sell new/used and reproduction parts for your Ford trucks, and 20 of them sponsor this forum. = Look on this page for, among others: Blue Oval Truck Parts; MAR-K; Mike's Truck Salvage; Green Sales; Auto-Krafters; National Parts Depot and Mac's Antique Auto Parts. Excepting Green Sales and Mike's, all the others offer free catalogs.
CAVEAT EMPTOR: lmc sells a lot of Chinese made crappola, and is not an FTE sponsor.
Old Dec 16, 2007 | 03:06 PM
starmilt's Avatar
starmilt
Drums are not in the same class as discs especially on 4x4s where you get them wet.
Old Dec 16, 2007 | 04:10 PM
starmilt's Avatar
starmilt
never played with 4x4 on the slicks but I am thinking you will have to do some fab work for power steering. a c6 from later fe motors will bolt to your motor these are easy to find and cheap to rebuid. may be easier to find a 70's frame and gear change body I hear on here the cab is a bolt on the holes are in your cab to bolt the power brake setup on.
Old Dec 16, 2007 | 04:22 PM
garbz2's Avatar
garbz2
A 65 F100 four wheel drive will not bolt on to a 65 up 2 wheel drive frame. 65 four wheel drives still used the early 61 to 64 cabs.
The 65 F100 shared the same frame as a 59 to 65 F100 Factory four wheel drive. Yes they can be modified to work on a later frame by adding a more rearward front cab mount to the frame.
1966 F100 four wheel drives share the 65 66 2 wheel drive cabs.
The only bolt on power steering is a push pull hydraulic type that ford offered for the straight axle trucks. The 65 F100 4x4 used the Gemmer integral shaft box. A popular swap is a mid eighties toyota box and custom Pittman arm, with your steering collum and shaft modified to fit. It takes fabrication skills to do this swap or a hefty wallet to pay some one to do it.
No disc brake swaps are currently offered for the pre 66 F100s five lug front closed knuckle axle. There is a swap kit offered for the eight lug danas.
Garbz
Old Dec 16, 2007 | 04:27 PM
garbz2's Avatar
garbz2
A C6 truck trans short tail shaft with bolt on yolk is needed behind the FE as the Tcase in 65 is still divorced from the trans. A long shaft car or later truck trans with a slip shaft will fit, but require a custom fabricated really short propeller shaft.
Garbz
Old Dec 16, 2007 | 04:32 PM
starmilt's Avatar
starmilt
That means that the power brake booster wont be a bolt on either if they used 64 cabs is this right.
Old Dec 17, 2007 | 08:10 PM
texasborn's Avatar
texasborn
thanks for your input guys!! think I'll look for a 2wd body & swap to a 78-9 4x4 frame.
Old Dec 17, 2007 | 08:24 PM
matt2491's Avatar
matt2491
I've learned (and experienced) since being here that other REAL companies like Dennis Carpenter for example kicks the ***** out of LMC!
