Decode '64 F100 please
Old Apr 24, 2014 | 04:24 PM
1965GTFB's Avatar
1965GTFB
Door tag is:
F10JR481382
128 YM F100 B81 A 12
5000 114 3600 72
Thanks
Old Apr 24, 2014 | 06:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1965GTFB
F10JR481382 / WB: 128 / COLOR: YM / MODEL: F100 / BODY: B81 / TRANS: A / AXLE: 12 / MAX GVW LBS: 5000 / CERT NET HP: 135 / RPM: 3600 / DSO: 72
F10 = F100 2WD
J = 223 1V I-6.
R = San Jose CA Assembly Plant.
481382 = 1964, assembled December 1963.
128" Wheelbase.
YM: Y = Skylite Blue / M = Wimbledon White.
F100 2WD, 5,000 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Check Stripe Woven Plastic / 81 = 81B Custom Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,600 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 21, 2015 | 08:05 PM
grandpasf250's Avatar
grandpasf250
Hey guys new to the site:
I have figured out most of my vin, but I have no Idea what the other numbers.
F25CD460471 1207 I know that "f25= f250, C= v8 292 cid 2 bc carb, D= Dallas" as far as the "460471 1207" I am lost.
M 5 0 07K 24 A M is " corinthian white" , but don't under stand the '5 0 07k 24 A".
10 16 63 62002 0 3rd line is just a mystery "10 16 63 62002 0"
Can any one help fill in the gaps???? I will post a picture of the card.
This small plastic card was in my Grandpa's wallet I scanned it to enlarge it
Last edited by grandpasf250; Apr 21, 2015 at 10:49 PM. Reason: misses spell word...
Old Apr 21, 2015 | 10:42 PM
grandpasf250
Can any one decode this for me?
Old Apr 22, 2015 | 10:30 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Any decoding I have done has been of the Warranty Plate - a metal plate attached to the truck.
That is a great piece of documentation you have there for your truck and it tells some info. The 460471 is the consecutive number of your truck and indicates it was built in September of 1963 - a 1964 year truck - Your piece of paper says 10/16/63 on the third row which is likely the day it was purchased by the new owner. The paper ties the truck to a person. The Warranty Plate is just about how the truck was equipped from the factory - no correlation to a person - that's what we use to decode typically.
The 24 and A are the rear axle and transmission most likely, but they are probably also on the Warranty Plate. Take a picture of the Warranty Plate and post in and I can decode it for you - or anybody else.
Old Apr 24, 2015 | 03:13 PM
NumberDummy
07K is probably the date the truck was assembled: October (K) 7, 1963.
A = January, M = December. The letter I is skipped.
Murphy1966
Oct 30, 2018 11:04 AM
yozsi
Jan 9, 2017 02:20 PM
diesldoct
Apr 25, 2014 12:05 PM
1965GTFB
Jan 21, 2011 01:13 AM
Herky737
Oct 20, 2010 06:40 PM
