Axle code 02J
Old Dec 3, 2007 | 08:44 AM
byro01's Avatar
byro01
Axle code 02J
I have a 73 F-100 with an axle code of 02J. I have done some reading and I am assuming the axle code is just 02, but since it is 2wd the J is something about power steering? I entered this into the one recommended website and it said this was a 2750# 3.00 axle. Is this the axle ration 3.00. The reason I ask this is because when I drive over about 60mph the truck sounds like it's about to explode. It turns so many rpm's it would probaly die before it ever hit 80. Is this normal with a 3spd automatic or is this a lower gear than a 3.00. Thanks
Old Dec 3, 2007 | 12:01 PM
Mil1ion's Avatar
Mil1ion
02 for 1973 is a 3.00:1 RATIO
J = Power steering on a certain GVWR front axle.
Perhaps the rear diff gears ahve been replaced with something else.
A door code is just a code from the factory.
You may have to crack it open ...count the gears and do the math
byro01
Jul 12, 2009 06:48 AM
Davetopay
Oct 6, 2008 04:01 PM
Ranger GT2
Jun 19, 2007 02:41 PM
69fastback393
Jun 28, 2006 08:15 PM
BigShelby
Feb 16, 2003 09:02 PM
