02j axle code 78 f100
Old Jun 15, 2006 | 01:18 PM
69fastback393's Avatar
69fastback393
i have a 78 f100 axle code o2j w/ a dana rear.can anyone tell me what gear ratio it is? i am running a 95 5.0 w/aode and overdrive is useless.my guess it is between 2:79 and 3:00 because it is like your taking off in 2nd gear.if anyone is using this setup what gears are you using............................thanks
Old Jun 15, 2006 | 01:22 PM
Mil1ion's Avatar
Mil1ion
No 02 code in 78.
The J stands for power steering.
Better check closer.
The 02 codes applies to 76's & 77's and it is a 3.00:1
a 02 code is also a 9" not a dana.
Btw, you can verify it here on my page.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Jun 15, 2006 | 01:34 PM
69fastback393
i went back and checked and it is in fact a 02 axle code w/dana rear.this truck is all original. i purchased it from my neighbor who purchased it new.somewhere in past forums i read someone else talking about the same issue.its my luck to have an oddball.
Old Jun 15, 2006 | 01:48 PM
Mil1ion's Avatar
Mil1ion
What are the last digits of the VIN#
Old Jun 15, 2006 | 02:52 PM
69fastback393
1569.....thanks
Old Jun 15, 2006 | 03:00 PM
Mil1ion's Avatar
Mil1ion
Sorry there should have been a 6 in front of Last in the other reply
I need the next 2 for a total of the last 6.
also, what is the complete DSO code
Old Jun 19, 2006 | 08:28 PM
69fastback393
sorry it took so long to post,i have been out of town.ok,here are the numbers on the tag. VIN# F10GNCG1569 type/gvw ..F100 body ..CD4 trans ..G AXLE ..02j dso..22. hope this helps........thanks
Old Jun 19, 2006 | 10:43 PM
Mil1ion's Avatar
Mil1ion
The Truck is a late 78.... July 1978 actually
My thought : Possible mis-stamping of the axle code.
code 22 is a dana 61 - 3.07 Ratio ....5300 lb axle
Does that ratio seem correct ?
Old Jun 20, 2006 | 08:31 PM
69fastback393
my guess is it is around a 2:75.from the pics that i looked at on a website it appears to be a dana 44.
Old Jun 20, 2006 | 09:31 PM
STGFordCrazy04's Avatar
STGFordCrazy04
F100 axles. they could come either way
D44- differential cover that can be unbolted from the rear to expose gears. 2900lb capacity 2.75 and 3.00 were the only ratios available and no option for limited slip
9"- no differential cover. hoghead has to be pulled to inspect gears. Center section very round and about basketball size. 3750lb capacity 3.00 3.25 ratios for F100 limited slip an option and more aftermarket parts than you can shake a stick at. these axles are as easy to find as 350 chevy parts.
That is the quickest way to visually check the axle in the truck.
Old Jun 28, 2006 | 08:15 PM
69fastback393
i finally found the tag and it is a 2:72 dana 44.
brown78
Dec 12, 2021 04:49 AM
greentruck72
May 20, 2015 03:13 PM
luckyjoe
Sep 28, 2010 05:10 PM
lynn s 460
May 3, 2010 08:27 PM
briansspeedshop
Mar 20, 2005 03:23 PM
