Boost
Old Nov 29, 2007 | 04:57 PM
cstorms's Avatar
cstorms
Question Boost
What would make my boost gauge go from 4 down to 0 and back again at 60mph ? I can hear a hissing sound when it drops and it stops when it comes back up. when I stand on it plenty of power. No chip just gauges and 4in exhust.
Old Nov 29, 2007 | 05:01 PM
dryfly's Avatar
dryfly
Is the hissing comming from what seems the pass side?and is this doing it all the timee or just when the engine hasent fully warmed up?
Old Nov 29, 2007 | 05:05 PM
cstorms's Avatar
cstorms
from pass side and when not fully warmed up
Old Nov 29, 2007 | 05:18 PM
ron's power stroke's Avatar
ron's power stroke
that would be your EBPV (exhaust back pressure valve)..it aids in warming up the truck..if you let your truck sit long enough at cold start up..it will start to run at a high idle..a valve will close in the exhaust to build a load on the engine to help it warm faster..when it does close at high idle and parked..and you have a strait pipe exhaust.it sounds like a fighter jet taking off..when temps come up to norm..it will stop closing..
Old Nov 29, 2007 | 05:19 PM
dryfly's Avatar
dryfly
Thats normal.Its your EBPV(exhaust backpressure bypass valve).So iF understand it correctlly.is used to bring the engine up to operating temps qiucker in cold climates.It does this in the way of bypassing the turbo charger when there is no load demand on the engine.Do a search on "ebpv"and you'll get tons of info.Such as what to do when you dont here the hiss on cold morns.And you have noticed a loss in power.
Old Nov 29, 2007 | 05:33 PM
cstorms's Avatar
cstorms
The only thing is it did't do this last winter.
Old Nov 29, 2007 | 05:43 PM
ron's power stroke
does it do this after the truck warms up ?? did you have the 4" exhaust on last winter ??
dieselsmoker
Apr 9, 2011 11:29 AM
muddrag1
Oct 31, 2008 01:40 PM
smoky_diesel
20
Feb 8, 2008 06:35 PM
schmity
13
Sep 13, 2006 12:27 PM
Scott KY
Oct 5, 2004 06:42 PM
