Boost #'s don't match with chip.
Old Sep 12, 2006 | 08:39 PM
schmity's Avatar
schmity
Recently purchased autoenginuity(AE). When comparing the turbo boost from my pillar gauge and AE, AE was consistenly 4-5#'s less than the pillar guage. Switched my flip chip back to stock setting and AE matched pillar. I am running a 4 pos DP tuner chip (I'm not sure which tunes) but on all three of Jody's tunes boost on AE is 4-5#'s less than pillar gauge. Just thought I would share.
Old Sep 12, 2006 | 08:50 PM
ponch37300's Avatar
ponch37300
Sounds funny. I don't have ae but will be interesting to see what people say. Whereis your boost gauge hooked up? Do you have an overboost regulator? Where does the ae take the measurement from?
Old Sep 12, 2006 | 08:51 PM
Pocket's Avatar
Pocket
AE is reading boost from the MAP sensor. If you have a blowoff valve or boost regulator, then I'm guessing that's why the readings are mismatched.
Old Sep 12, 2006 | 08:53 PM
Uzumati's Avatar
Uzumati
what version are you using 4.2 had issues with the manifold gauge pressure reading correctly. the new 4.3 just released a few weeks ago fixed it
Old Sep 12, 2006 | 09:04 PM
schmity's Avatar
schmity
AE reads the MAP sensor. While towing down the highway with my pillar gauge reading 10#'s AE reads 6#'s. The second I switch back to the stock setting (and I do mean the second) AE jumps from 6#'s to 10#'s. Change back to jody's tunes and AE jumps back to 6#'s. This has stumped me for a while, and I even bought a new MAP sensor that didn't change anything. I'll check the AE version, but I don't think that is the problem. MAP sensor doesn't have a blow-off or regulator. Pillar boost gauge is plumbed after the intercooler.
Looks like Jody would want the boost to read higher so that it would pump more fuel. This is exacly opposite.
Old Sep 12, 2006 | 09:34 PM
Uzumati's Avatar
Uzumati
If you are only reading 6# on MAP you are reading -8# of boost since abient is around 14.6 depending on weather.
The MAP is the Baro (abient Pressure) reading + Manifold Guage Pressure (Boost)
he could be lowering the Baro a few PSI but I cant think of why.
Old Sep 12, 2006 | 09:51 PM
schmity's Avatar
schmity
In AE you can either read absolute pressure or gauge pressure. I was looking at gauge pressure which would be equivalent to pillar gauge boost pressure.
Old Sep 13, 2006 | 04:40 AM
jetdoc's Avatar
jetdoc
Maybe programming "fools" the MAP to a lower pressure reading to increase boost.
Old Sep 13, 2006 | 07:35 AM
Uzumati's Avatar
Uzumati
Gauge pressure should match the pillar gauge since you dont have a regulator and even then it would only be different in an overboost situation. My vote would be for Jody lowering the reported value a little. All he has to do to pump more fuel would be to raise the IPR Duty Cycle a little an by lowering the boost the PCM is seeing he is Defueling later.
Old Sep 13, 2006 | 08:51 AM
Vengeance's Avatar
Vengeance
Would explain that in a little more detail? Not quite sure what your saying.
Old Sep 13, 2006 | 09:34 AM
Uzumati's Avatar
Uzumati
The ICP reads the pressure in the HP oil rail and the PCM decides if more or less fuel is needed due to throttle position and a few other variables. if more oil pressure is needed to provide more fuel the PCM commands the IPR to open more (Increase duty cycle) thus increasing ICP pressure and fuel flow. Now the PCM will begin to defuel at around 25psi of boost so if jody is lowering the boost number the PCM is seeing then you are actually over that 25psi reading when you begin to defuel.
Old Sep 13, 2006 | 10:54 AM
Vengeance's Avatar
Vengeance
Raising or lowering the ICP has no effect on the amount of fuel that is delivered, neither does the increasing of the IPR. All that does is increase the pressure that the fuel is injected into the cylinder with.
The only way to "fool" the pcm from seeing boost is with a regulator or something like it in front of the map sensor.
Old Sep 13, 2006 | 12:26 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Sep 13, 2006 | 12:27 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
schmity,
sent you a PM...
__________________
snakedoc
Oct 10, 2013 05:08 PM
lud04X
20
Oct 26, 2011 07:20 PM
travisd
Dec 21, 2006 04:29 PM
TNT in Round Rock
Sep 19, 2004 12:30 PM
96-5spd302
Mar 15, 2004 06:09 PM
