Boost gauge problem
Old Oct 1, 2004 | 09:03 PM
Scott KY's Avatar
Scott KY
Boost gauge problem
I recently had a hypermax combination pyrometer and boost gauge installed in my 97 PSD. The boost gauge needle flutters rapidly between 10 and 15 when I accelerate hard. The line that runs to the boost gauge tee's off of the rubber hose that goes to the map sensor. Any ideas why the gauge fluctuates so much?
Old Oct 1, 2004 | 10:55 PM
Kwikkordead's Avatar
Kwikkordead
Is the fluctuation accompanied by a pulsing sound coming from your intake? If so I suspect compressor stall. But from what I have been able to gather through reading lots of posts here you have the good compressor wheel. So I don't know for sure here.
Old Oct 1, 2004 | 11:15 PM
FoMoCo136's Avatar
FoMoCo136
My 2003 will do it. I need a Wicked Wheel!!
Old Oct 1, 2004 | 11:25 PM
Kwikkordead
I HIGHLY recommend doing that. I just did it to mine and the new sound is well worth the expense. All traces of intake chuffa chuffa chuffa sound are gone and replaced with a making semi truck turbo whine. And the exhaust flutter is greatly reduced too somehow.
Old Oct 1, 2004 | 11:36 PM
FoMoCo136's Avatar
FoMoCo136
My trailer will kill my turbo if I don't do it. Mine is about 10,500lbs and climbing hills the turbo chug is much more of a concern than temps. I gotta lift to get the noise to go away.
Old Oct 4, 2004 | 10:53 AM
Silverrv's Avatar
Silverrv
Tell me more about this Wicked Wheel..??
Old Oct 4, 2004 | 09:40 PM
Kwikkordead
You could end up with a whole evening's worth of reading if you did a search on it. Long story short: 99.5-2003 7.3 liter PSD Ford's were equipped with a type of turbo intake wheel that is very inefficient at certain times. They make a stacatto chuffing noise when pulling heavy loads uphill full throttle at around 2000 rpm. The cure is to install the "Wicked Wheel" which is basically the same turbo compressor wheel as the earlier PSD engines had.
Old Oct 5, 2004 | 04:59 PM
RedStroker6's Avatar
RedStroker6
so my wheel in my '95 PSD is fine then? haven't noticed any noises....other than that big loud one since i seem to have misplaced my cat converter....
Old Oct 5, 2004 | 06:42 PM
Fire Rooster's Avatar
Fire Rooster
I would closely inspect your impeller for any bends or breaks in the veins. It sounds as if the impeller has an imperfection to it. Because your stock impeller on that year should not stutter. Remove the intake boot right next to the turbo and take a looky.
Fire Rooster
cdiddy
Jan 4, 2008 11:38 PM
pip-clark
16
Sep 7, 2007 09:44 PM
FORDSDOWNER
Aug 27, 2007 03:17 AM
sean23johnson
44
Jan 9, 2007 10:54 PM
Gage2502
Modular V10 (6.8l)
Feb 25, 2006 11:42 AM
